01-16-2021, 10:51 AM | #15 | |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Never mind!!! I just noticed that tire sticker above my VIN sticker duh. I’m gonna have to go look at it to see how accurate it is. I should really look closer at my pictures before posting. Haha Last edited by Scottyz; 02-15-2022 at 04:24 AM. |
01-16-2021, 11:01 AM | #16 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Pretty sure it is the same in Canada...
01-16-2021, 11:30 AM | #17 | |
The only way to know the weight is on a scale.
'20 ZL1 1LE A10,
01-16-2021, 11:43 AM | #18 | |
Look at my 2 images. The weight of the car is the GVWR minus the occupant/cargo. Both are on the door jam. This is the curb weight of the vehicle as it left the factory including all fluids. |
01-16-2021, 12:29 PM | #19 |
Drives: 2016 hyper blue 2ss Join Date: Nov 2017
Again, as the poster above mentioned, that’s the most it CAN weigh. Not what it DOES weigh
2016 HBM 2ss m6 with MRC and NPP
1992 mr2 turbo m5 |
01-16-2021, 12:55 PM | #20 | |
EDIT - I even have the 2 stickers posted above his post - post #16 Edit Edit and I even have it circled (or highlighted or squared) |
01-16-2021, 01:23 PM | #21 |
FarmerFran, the GVWR data on the door jamb sticker is not the car's curb weight. I posted the weights from the 2020 order book, that is the official info. The other sticker displays the tires' max load info.
It's 3883 pounds for the 2020 ZL1 1LE coupe with the A10, so 3600 lbs after installing a larger supercharger and additional parts doesn't make sense to me, unless significant weight saving steps were also taken.
01-16-2021, 01:25 PM | #22 |
The actual weight of my car is NOT in the door jamb. Perhaps I got jipped.
'20 ZL1 1LE A10,
01-16-2021, 01:28 PM | #23 |
What is GVWR - it is the vehicle weight plus all fluids AND the occupants and cargo
It is on sticker #1 on sticker #2 there is the maximum occupants and cargo. the difference is the weight of the car. |
01-16-2021, 01:30 PM | #24 | ||
It is on sticker #1 on sticker #2 is the maximum occupants and cargo. the difference is the weight of the car. I never once said the GVWR was the weight of the car - I said the 2 stickers will tell you the weight of the car. Go look at your stickers... here I will post mine again... |
01-16-2021, 01:32 PM | #25 | |
I’m inclined to agree with you.... https://www.ezcarlift.com/PDFs/ezcarlift_curbcalc.pdf |
01-16-2021, 01:42 PM | #26 |
Well, even though GVWR - all fluids - max tire loading = curb weight, I don't think fluids are typically considered as part of the car's weight for comparisons, because it would mean a variance of up to ~160 lbs (empty vs full tank), which makes these discussions difficult and error prone.
01-16-2021, 01:53 PM | #27 | |
What do your 2 stickers say? |
01-16-2021, 01:53 PM | #28 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
FarmerFan is 100% correct.
Gross weight minus occupancy weight equals your actual vehicle weight. It's been this way for years and years on GM cars and most others. |
