01-11-2021, 11:34 AM | #1 |
Drives: 2021 Camaro LT1 Join Date: Jan 2021
Switched fuse in rear fuse box—2021 LT1
Hello everyone! I picked up my LT1 Camaro last weekend and I’m looking to hardwire a dash cam. I’ve read a bunch of threads but most of them revolve around the SS trim which has different options and fuses. Ideally I would like to run my hardwire kit back to the trunk fuse box and just use fuse taps for the constant and switched lines.
So, my question is simple: has anyone found a switched fuse in the back fuse box of the LT1 trim? The only options I have on my car are the tech package (8” screen with Bose), automatic transmission and dual mode exhaust. I checked the fuse for the radio, amp, and HVAC. They all have constant power (the amp fuse has about half the power of the others). I know this has been a struggle for a lot of people, but I figured I would check before trying to tap into the cigarette lighter or the wire for the airbag light in the upper console. Thanks in advance! |
01-11-2021, 09:42 PM | #2 |
Drives: 2019 Camaro 2SS Join Date: Jan 2019
i do car audio installation..... i used the bcm ign wire under the drivers dash... very simple
01-12-2021, 01:24 PM | #3 |
Thanks for the tip. If I can’t find one in the trunk I’ll probably tap into the passenger airbag light in the upper console. Is anyone aware of any issues with this?
01-12-2021, 02:19 PM | #4 |
Drives: SRT4, 2ss Join Date: Nov 2016
I used the fuse for the wireless charger as my switched 12v source.
01-13-2021, 07:56 AM | #5 |
06-20-2022, 05:43 PM | #6 |
Drives: 2022 Camaro LT1 Join Date: Mar 2022
Reviving this thread to see if any LT1 owners know about a switched fuse in the trunk. I'm looking to hardwire a dash cam back there also, with one constant fuse and one switched fuse. But maybe I need to find a different solution
07-11-2022, 10:44 AM | #7 | ||
D3RPZILLA
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
07-11-2022, 02:29 PM | #8 | |
Electrical Engineer
My simple rule: only tap a circuit you don't actually need. BCM/ECM or SRS are a no-go in my book. Best way to add power in a car is to use relays to generate switched signals while avoiding adding load to existing circuits. A bit more effort but it insures you're not impacting OEM systems. ACDelcoTDS Website allows you to view/print schematics for your year/trim for a small fee over a day or two (might as well snag a bunch of stuff while you're in there).
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
