12-25-2020, 01:19 PM | #15 | |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Also I use the quickjacks and was concerned how tiles would work with them |
12-25-2020, 08:34 PM | #16 |
That should be okay even with less capable tiles, your quickjacks most likely spread the load out over a much larger surface than jack stands. Even the "standard" tiles I used exhibit no problems at all with large SUVs, no creaking, no deformation or cracking, so I think you'd be okay. Even if they did crack, by the way, you can easily replace them individually with stronger, identically colored counterparts. Alternatively, you can incorporate a "desired tire track" with stronger tiles of a different color into your design. Lots of possibilities to make adjustments even after installation.
12-26-2020, 03:42 PM | #17 |
Drives: Camaro 2020 2SS VERT Join Date: Dec 2020
I cant help myself
12-26-2020, 06:34 PM | #18 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
12-26-2020, 06:56 PM | #19 |
Even with the cover on, the lines on the car are accentuated. She’s a beauty.
12-26-2020, 07:00 PM | #20 |
Thank you. Here’s the other end.
12-27-2020, 03:02 PM | #21 |
Drives: 2007 Honda Civic Join Date: Apr 2018
Best seat in the house is say!
It’s not as nice as some of your garages here, but the plan is to change that all over the next 3 years as the finances will allow. |
12-27-2020, 05:28 PM | #22 |
Very nice North👍
12-27-2020, 07:39 PM | #23 |
Drives: 2020 2SS 1LE Satin Steel Metallic Join Date: May 2020
I don’t hang out in the Garage but usually when I have to get something I will frequently tap the door handle and say I can’t wait until spring/summer to take her out and rip up the roads. |
12-27-2020, 09:25 PM | #24 |
12-27-2020, 09:26 PM | #25 | |
12-28-2020, 05:51 AM | #26 |
01-01-2021, 12:29 PM | #27 |
Had to start it today, weather not too bad, put some Maguires’s rich leather on the seats. She sounds sooo good. 😂
01-01-2021, 12:35 PM | #28 |
Yes cold starts do sound very nice😈
