05-04-2021, 09:23 PM | #15 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I'm sure you or the tire place have, but did you spray around / in the valve stem? its rare, but sometimes the little needle thing inside the stem isn't screwed in all the way.
05-05-2021, 12:00 PM | #16 |
If he went to 48 psi it may have popped the bead into position.
on a side note... Your detailer does tires on the side? pretty sure the balancer has to be calibrated at certain intervals. Usually the mounting machine and balancer equipment is kinda pricey and you need the volume to justify the expense. |
05-05-2021, 03:27 PM | #17 | ||
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
