03-17-2023, 09:02 PM | #1 |
Drives: 2010 Camaro SS A6 Join Date: Oct 2018
LSD options
Hello. What is everyone using for their LSD in regards to the Drag Strip. I see that Eaton only made the TRU-TRAC through 2015 for the Camaro. I thought I saw a helical gear LSD from Yukon and then another from another company that I've never heard of.
Thanks |
03-18-2023, 03:26 PM | #2 |
Yup, they hold up to a lot of HP, big HP. You'll probably break an axle or driveshaft before the diff.
03-18-2023, 04:21 PM | #3 |
Can confirm the DS breaks before the diff.
03-18-2023, 08:19 PM | #4 |
Thanks for the reply. I see now the diff itself is strong. My concern was if the diff is like most std limited slip diffs that use clutch plates that eventually wear out especially if drag racing. I know the tru-trac which was a huge player on the 2010-2015 camaro ss, uses a helical gear type lsd and doesn't use clutch plates. Just curious about the current "type" of LSD in camaros and why Eaton doesn't make a tru-trac for the 6th gen camaro.
03-19-2023, 07:59 PM | #5 | |
03-19-2023, 09:30 PM | #6 | |
Drives: 2016 2SS Convertible Join Date: May 2012
https://www.camaro6.com/forums/showthread.php?t=547186 |
