03-01-2023, 03:13 PM | #29 |
In case no one else mentioned it... get a Dragy! They work great! No trip to the track required. Very accurate.
03-01-2023, 04:22 PM | #30 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Trouble with that is how do you do a good burnout on the street and rarely can you get the bite from a dig like you can on a prepped surface which kind of works against you imo. Good practice though for 60 ft times and 0-60 time. Hell if you can improve in those two areas on the street, you should be better on the track also.
03-12-2023, 06:02 PM | #31 |
Update: Did much better this time. 2000+ DA. 90 degrees out.
My best run was 1.9 60ft with a 12.6. Pretty stoked I got a 1.9 on the Goodyears, didn’t think that would happen. I’m car #63
2019 Camaro SS 1SS 6MT - GM CAI
03-12-2023, 06:18 PM | #32 | |
BTW, At 90 degrees, what was the DA reading of the day? Last edited by lt4camaro; 03-12-2023 at 07:06 PM. |
03-12-2023, 08:19 PM | #33 | |
In the morning when the DA was around 1200 and temps were in the 70’s I was trapping 114 but my times were high 12s low 13s 2.2 2.1 60’s. As it got hotter I noticed trap speed go down but 60’s were getting better. Then I ripped my PB for the day.
03-13-2023, 09:13 AM | #34 | |
03-13-2023, 03:51 PM | #35 | |
Thread Tools | |
