11-19-2022, 03:47 PM | #29 |
Just bought a battery tender and connected to the terminal under the hood.
After a bout 1 hour still red? Reading that sometimes it needs to be connected on the battery. I tore the trunk apart and hooked it directly to the battery using the bolt on connections. Put it all back together and plugged it in. Still nothing but red light on the tender? I have checked all fuses and car was ran 4 days ago. It is about 20 degrees outside but this is a 2022 with 2500 miles? The only thing I can do is let it charge overnight and see if it goes green? The same charger charges motorcycle and mowers fine?
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
11-19-2022, 03:53 PM | #30 | |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Also, iF your battery charger is one that has different settings for conventional batteries and Lithium batteries, you need to make sure you have it on the correct setting. Finally, if the battery was TOO discharged to rescue, the Battery Tender signals that via one of its lights (different lights on different Battery Tender models). And, a battery that dead can also blow the Battery Tender fuse because it has a short inside the battery. That is what happened with the discharged battery someone gave me to try to rescue. Jim G |
11-19-2022, 04:44 PM | #31 | |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
11-19-2022, 10:45 PM | #32 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
If I know I’m not going to be driving my Camaro for several days or if it’s going to be particularly cold, I connect the tender under the hood. When I get back to the car it’s good to go. The few times where I have not connected the tender and let it sit long enough to discharge the battery I have had to jump the battery with another car or my 650 amp charger. As I type this my tender is connected under the hood.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
11-20-2022, 08:45 AM | #33 |
Battery tender finally went green light after charging all night
I will leave in on until time to drive when the weather warms up.
2022 Black ZL1
11-20-2022, 04:04 PM | #34 |
Drives: Audi RS3 Join Date: Aug 2022
I haven't seen any mention of "C-Tek" battery chargers/maintainers in this thread.
A popular model is the MX5,...it will charge & maintain batteries, is well made & very reliable. It will regenerate & charge batteries & then keep them fully charged,...leave it on as long as you like, it will not over charge your battery. Google is your friend! Pickles. |
11-20-2022, 04:11 PM | #35 | |
SOME of the "Battery tender" brand models can also do Lithium batteries, but some cannot. Right now, Lithium batteires for cars are still expensive, but with the recent dramtic price increases in regular batteries, the Lithium batteries prices are "only" about double what the regular batteries cost. Lithium batteries have VERY high cold cranking amps, weigh a fraction of what regular batteries weigh, and self-discharge much more slowly. Jim G |
11-20-2022, 06:21 PM | #36 | |
I'm hopeless mechanically, but I've had my C-Tek for many years & it does the job easily & reliably, over a number of years on different cars. Pickles. |
11-20-2022, 08:40 PM | #37 |
I could be completely wrong but I thought C-Tek was the private label for the tender being sold as a Camaro/GM option.
11-20-2022, 09:01 PM | #38 |
The Griot’s Garage Battery Manager V is really great in my humble opinion and does more for your battery than a regular trickle charger. Works with lithium ion batteries too. It came with a number of different harnesses including a quick-connect version that I bolted to the main power distribution block under the hood. When I get home I just plug in into the harness and good to go.
11-20-2022, 09:26 PM | #39 | |
Retired from GM
C-Tek offers a broad range of tenders and chargers beyond the one that is also available with Camaro logo.
11-20-2022, 10:27 PM | #40 |
I took a quickk look at the C-Tek website. It appears that they have ONE model that does Lithium batteries, but it does not say if that model will also properly charge regular batteries. Its price in Canada is $193. None of their other models mention Lithium charging.
Jim G |
11-21-2022, 07:22 AM | #41 |
Old Gearhead
I just found out that Battery Tender makes a connector for the OBD port.
https://www.batterytender.com/Batter...ccessory-Cable
11-21-2022, 10:11 AM | #42 | |
1. The instructions say: "The OBDII connector is a standard connection point to the battery on all new vehicles that will allow you to set the 5 watt panel on your dash and charge / maintain your vehicle battery from inside the vehicle." That SOUNDS like you might need to first do something called a "5 watt panel" setting on your dash. Maybe some vehicles have such a thing, but does a Camaro? 2. The OBD2 port is designed to transmit low-amperage electronic signals, not transmit the kind of power to recharge a weak battery. So, such an approach might work to MAINTAIN a battery, but not to charge a battery that needs more than a very small current to recharge. I'd find out more before going this way. Jim G |
