10-18-2022, 09:11 AM | #1 |
New PB but...
Got to a TNT on Saturday and ran a new PB but not without damaging the motor I am thinking!!! The MPH is way off so whatever happened it happened during the run! After I went thru the traps the car shutoff... I put it in neutral and was able to steer it off of the track. Tried to crank it over and it barely turned over once than nothing! got it home and removed the plugs and removed all of the belts... cant turn the motor over with a breaker bar on the crank! Next I am gonna drain the oil and cut open the filter and see what i can find! Been told by a few folks that over 900WHP some of these LT4's have crankshaft walk issues! Has anyone heard of this? I just had the transmission rebuilt and a new circle D converter installed so i was hoping something happened with that but it doesn't look like it so far!
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
10-18-2022, 02:32 PM | #2 |
Worst case confirmed!!!
2018 ZL1-NFG-A10
10-18-2022, 02:37 PM | #3 |
Did it bend the rod or bearing seized up on the crank. Man I have been there and know exactly how you feel. I broke the crank in a forged motor, it broke internally and the Lt1 broke 2 ring lands. Its just a bad feeling and I know your feeling the burn right now. Sorry for the damage it incurred. But it was a great pass.
10-19-2022, 08:08 AM | #4 | |
2018 ZL1-NFG-A10
10-19-2022, 08:20 AM | #5 |
Solid pass!! My guess is Thrust bearing failure. That is the weak link in the LT4.
2016 NFG 1SS A8
10-19-2022, 08:57 AM | #6 |
Thanks! It didnt hurt quite as much when i saw the slip! Thats what I am hearing as well about the crank walking.. that would certainly do it!
2018 ZL1-NFG-A10
10-19-2022, 10:18 AM | #7 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
Wow that’s moving . Sorry to hear about the motor .
10-19-2022, 10:51 AM | #8 |
Thanks! Most def biter sweet!
2018 ZL1-NFG-A10
10-19-2022, 11:19 AM | #9 |
I suspect this could have happened due to the torque converter installation. If they didn’t double check crank end play and the TC mounting tabs were a hair thicker than stock, you’re done.
10-19-2022, 11:57 AM | #10 |
This is a possibility! I am probably going to take this thing apart myself so I can see for myself if it was dues to the converter! I did drive it quite a bit after the converter was installed and it didnt have any issues...
2018 ZL1-NFG-A10
10-19-2022, 03:00 PM | #11 |
Those are well know for Oil Pump failure also and as King said fried bearings including the thrust bearing are very possible. Usually when the basically lock up like that its a rod bearing. A buddy of mine had to rod bearings lock up on the dyno. You could not turn it over.
10-19-2022, 04:43 PM | #12 | ||
I’m not a gambling man, but… <pushes pile of chips to the center of the table>
10-19-2022, 06:12 PM | #13 | |
2018 ZL1-NFG-A10
11-09-2022, 11:49 AM | #14 |
Pulled the motor and dropped the pan... as you can see in this pic the Thrust bearing spun and I am guessing it covered the oil hole which in turn burnt the bearing on cylinder #3 and #4! Not sure what will be salvageable here! I am really surprised this thing didnt throw a rod out the side of the block! Had to drop the engine and tranny at the same time because I couldnt turn the motor over to get to the converter bolts...
2018 ZL1-NFG-A10
