09-21-2017, 05:58 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Anybody running a 17x10.5 rim in the rear
Looking at the Race Star Drag Star wheels. I spoke to Race Star and was told the both the 9.5 &10.5 wide rim will fit the car. "Most" guys here and vendors sell and run the 9.5 wide rim. The rims have 6.0 inch and 7.0 backspace respectively so poke will be identical the rim is moved inboard an inch on the 10.5. I will run the same 305/45/17 MT ET street R regardless of wich rim I choose its just the 10.5 rim will flatten the tire out a bit more onto the ground. Car is stock ride height just looking for any info here thanks.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray Last edited by JFM-jr; 09-21-2017 at 07:46 AM. |
09-21-2017, 09:28 AM | #2 | |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
09-21-2017, 11:22 AM | #3 |
Ok great the ET Street R is actually a tiny bit Narrower than the SS so this should work out well. Thanks for posting
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
09-21-2017, 04:25 PM | #4 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
May want to consider a 315/35/17 26 tall tire. It is proven faster on cars with similar mods to ours
You'll do great with the 305 et street r and have more room to grow. I'm running them now. But you will go slightly quicker with your current setup and the 315 I bought some today hopefully it works for me too and I didn't waste money. I'll be keeping my 28 setup as well. |
09-21-2017, 05:44 PM | #5 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
17x10 welds on mine. No issues with the 28x10 slicks.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
09-21-2017, 06:40 PM | #6 | |
09-21-2017, 06:56 PM | #7 |
09-22-2017, 06:21 AM | #8 |
Yes I believe Bhill mentioned that and said power steering doesnt work when you pull the fuses
09-22-2017, 09:34 AM | #9 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Correct...IF my car actually reads NO TPMS sensors in all four wheels then I cam OK to be able to click two times for everything off. For some reason, the car sometimes does not read like that, therefore I have to pull the ABS Fuses to disable everything. And yes, your power steering is off as well. Not a big deal for me at the dragstrip tho. Like driving an old car without PS.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
09-22-2017, 10:37 AM | #10 | ||
The way I read your posts in the past sounded like the 26 tire setup caused another error with the abs system or something. Good to know it's just minor with the tpms. Once my drag pack has been on for about 20 miles and the system totally gives up my nannies will turn off and I'm good |
09-24-2017, 12:15 PM | #11 |
Tactical Garage
John,
Here are some body pictures of my set up. |
09-24-2017, 05:31 PM | #12 |
Thanks Rob!
09-25-2017, 07:23 AM | #13 |
Drives: . Join Date: Jan 2017
Loving this thread. Still trying to decide on what wheels I want in the rear. Are there any fitment issues related to my 1LE with 6 piston calipers?
09-25-2017, 02:38 PM | #14 |
I don’t think you’ll be able to squeeze a 17” wheel over them.
Thread Tools | |
