12-10-2019, 02:55 PM | #15 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Sorry - the message on his videos are kind of cryptic. Guess the a/c in the car is screwed so he has no interchiller on it currently
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
01-14-2020, 04:50 PM | #16 |
Drives: 2016 Camaro 2SS NGM Join Date: Jun 2014
whats a lash cap and whats a phaser limiter
01-14-2020, 08:38 PM | #17 |
Drives: SS 6 speed of course Join Date: Jan 2016
to make a larger fuel lobe the base circle is cut down, to make up for the room comp cams has a .080 lash cap and the .060 GM LS7 intake valve lash cap works. Might have reversed the size forget now. Anyway it has to be measured and ground to fit, I've always used the thinner one, the thick one needs to be cut (don't know why they make it). I have a completely standard thinner one in my engine now with a cam motion fuel lobe. My first cam was a Texas Speed lobe and I think I had to go to .022 for clearance.
There are guys that have zero lashed their stock stuff to get just a little more throw. Probably works as there is a reasonable amount of production slop to take up which equals to a slightly longer stroke say .010 or .005 or so.. The cam has a phaser that advances and retards the cam with oil pressure, my first cam required a 22 degree phaser, my second cam needed a compete lock but with valve reliefs and my smaller lift I could do a 5 degree limiter. The after market cams have more duration and lift and without the limiter / lock the valves will kiss the pistons and it is like kissing your sister..
01-15-2020, 12:51 AM | #18 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
I’ve developed an upgrade to the LT4 low side that might be helpful. It’s working well on my ‘17 ZL1 so far and hope to have data agains the stock ZL1 pump soon. My stock lowside ran out at E36ish.
