01-21-2020, 04:35 PM | #15 |
Drives: 15 Corvette E force Join Date: Dec 2019
I just did a cruise datalog after replacing the bypass vacuum hose and confirming the bypass Is operating correctly. My IATs at cruise are still +50*F over ambient temps. That’s the same amount my IATs were above ambient with the bypass vacuum line crushed, keeping my bypass closed.
01-21-2020, 05:04 PM | #16 |
Dyno Show Queen LOL
Hows the coolant level in the system.. maybe you have air in the system. If you have that clear T fill tube that a piece of crap it leaked all the time and caused air bubbles.
It also maybe that you need a better exchanger or a better pump. My wife is making 615 rwhp and 666 tq. But the SS has a larger grill for the exchanger to work. Logging on hers at idle for a while it was about 50 over ambient but once moving it comes down to 20 over. Hard 3rd then shift 4th to redline it would get to 150 degrees now this is humid summer weather. Haven't noticed any problems. I do know the traction button on ours has to be off if you just start it and go then make some pulls you can feel timing pulled.
01-21-2020, 05:25 PM | #17 | |
