Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 04-06-2016, 01:52 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro SS Stainless Works Full System Single Tip Performance connect
2016 Camaro SS Stainless Works Full Exhaust System Single Tip Performance Connection (Catless)
The Best In Performance & Sound
Our featured 2016 Camaro SS full system designed from headers to tips with 1-7/8" port-matched flanges, 3" off-road pipes and turbo S-tube mufflers. Choose between the stock Camaro configuration with two single tips or the Dual-Mode Performance Upgrade with quad tips.
Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers.
Features:
‣ 3" diameter system
‣ 1-7/8" off-road leads
‣ Port-Matched Flanges
‣ 3" AFM Valve Options Available
‣ Support For Dual-Mode Performance Upgrade Including Functioning Valve
‣ Aggressive exhaust growl
‣ Mirror-polished tips
‣ 304 stainless steel construction
‣ TIG welded for strength
‣ Mandrel bent (no buckling) for optimal flow
‣ Design and Made in Chagrin Falls, Ohio, USA
Performance and Sound Proudly Made in the USA
Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship.
Make It Your Own With Custom Options
Choose Your Connection: Stainless Works Camaro systems come in two configurations: Factory Connect and Performance Connect.
Factory Connect allows our headers or exhaust to easily bolt to the factory exhaust or manifolds respectively. They connect at the factory location which is necked-down to accommodate fitment.
Performance Connect is designed to take advantage of performance gains not possible with the standard factory connection point. Both SW headers and SW exhaust are used in this configuration. We've developed a system which maintains a full 3" diameter and X-pipe which creates the ultimate horsepower experience.
Item # CA16HORSTCB2
Website Link : http://www.rpidesigns.com/shop/item....em-single-tip/
RPIDon is offline   Reply With Quote
Old 08-05-2020, 07:57 AM   #2
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2016-2018 Camaro SS Stainless Works Full Exhaust System Single Tip Performance Connection (Catless)
RPI Designs is offline   Reply With Quote
