08-15-2022, 10:45 AM | #1 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
Lowering a ZL1
Which springs are the best when it comes to least ride quality change. I'm pretty picky about how the car rides. I'm wanting to reduce that fender gap some. What have you tried and how do you like it?
I've also put 5mm rear spacers and custom 11mm spacer in front w extended lugs to help with stance.
IG - @zl1_will
2022 zl1 740hp / 730tq stolen 2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms |
08-15-2022, 10:48 AM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
Eibach
J-Rod Built and Matt@FSP Tuned |
08-15-2022, 10:53 AM | #3 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Eibach.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| Borla S-Type Catback Exhaust| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
08-15-2022, 11:00 AM | #4 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Based on my reading/research/feedback from other form members, the Eibach seem to be the best on paper, BUT there have been quite a few people who have experienced major spring sag very fast, this drastically effects ride quality and appearance since you will be squatting in the back if this happens.
BMR seems to be the way to go, the front rates are the same as OEM, the rears are not much heavier. They are linear rate springs that will not have the same sag characteristics as the progressive Eibach rear design. On my personal car when I convert back to mag ride shocks, I will be giving the BMR springs a shot. |
08-15-2022, 12:30 PM | #5 | |
08-15-2022, 01:50 PM | #6 | |
08-15-2022, 02:13 PM | #7 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Eibach here since Dec of 2020, no issues at all.
08-15-2022, 02:37 PM | #8 |
You're pleased with their performance and ride?
IG - @zl1_will
08-15-2022, 05:06 PM | #9 |
08-15-2022, 06:24 PM | #10 |
Will I rub on the rear for the occasional drag strip day? I’ll have a 305/45/17 drag rear on for those days. If go with the Eibach springs
IG - @zl1_will
08-15-2022, 06:40 PM | #11 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Did most/all of you guys do the install yourself? If so, any tips or suggestions for those that may be considering the same? Thanks
08-15-2022, 07:14 PM | #12 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
For those of you who have a 2018-2022, how much lower did your car get lowered on the Eibach springs?
08-15-2022, 07:34 PM | #13 |
I’m an advisor at lexus so my techs are my performance shop, and I have tech friends
IG - @zl1_will
08-15-2022, 10:31 PM | #14 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
I ran the BMR as the eibach was a little lower than I wanted. Ride is great and lowered it just right.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, ARH 2 inch LT's, Stainless Works NPP Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
Thread Tools | |
