08-10-2022, 05:13 PM | #1 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
CT5 V Carbon Ceramic Brakes
Does anyone know if these will fit the ZL1?
08-14-2022, 02:16 PM | #2 |
Drives: 2022 ZLE 6M Join Date: Jun 2021
08-14-2022, 02:47 PM | #3 |
Drives: 1LEs Join Date: May 2009
These use the front caliper on the 2022 Camaro BCD J6H caliper but with vented pistons. They are CCB, so pads from C7 / C6 J57 CCM Corvettes don’t plant nice nor those from the 14 / 15 Z28. The rear of the CT5-V BW uses an extra external parking brake not a drum-in-hat e-brake like Gen 5 / 6 Camaros.
08-14-2022, 03:00 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Real question is are you going to actually use this on the track? If you're just getting it to get it because it's CCB, then why spend $10k on a piece that is designed to operate at high temps and gives the same performance (maybe worse) than the stock brakes while driving around town.
I understand people will do what they want but don't think that the CCBs offer better braking power over the stock brakes for a car that you'll only drive around town or on a nice Sunday. |
08-14-2022, 08:08 PM | #5 |
Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
But they do look very cool!
Lol. |
08-14-2022, 08:56 PM | #6 | |
08-14-2022, 08:58 PM | #7 | |
I'd be happy with just the fronts if I can use them. That's where the bulk of the weight savings are anyway. |
08-14-2022, 09:13 PM | #8 |
Making sure you weren't one of those people that wasn't CCBs because you know..... its CCBs and they look cool.
As far as I know, these CCBs use the same setup as the copper free brakes that the ZL1 and SS1LE can be optioned with. So that means you can't just swap out the rotors and pads, you'll need to change out the calipers as well unless your car already has the copper free brakes from the factory. |
08-14-2022, 09:17 PM | #9 | |
So I need: 1 - Front CCB Rotors and Pads 2 - Front ZL1 Rotors designed for the Copper Free brakes ....let me know if I'm missing anything. |
08-14-2022, 09:23 PM | #10 |
I doubt that the ZL1 copper free calipers will work as those calipers are designed for 390mm rotors and the CCB rotors are closer to 400mm.
I'm happy to do more research on this, but: I there a proper online parts catalogue for Cadillac? I can't find one.. :/ |
08-14-2022, 10:20 PM | #11 |
Who Needs to KNOW?
Most likely carry over parts from 2019 ZR1 or Z06.. maybe hat change to accommodate different offsets.
CCB rotors come in few common sizes, 390, 392, 394 x 36mm that can fit our cars. 390 being STOCK on ZL1. Rear.. not worth changing, minimal weight savings. Rockauto is good source of specs, NAPA used to be another, but new catalog system is kinda shit. GM parts catalog on many dealer parts department sometimes has good info, thickness, diameter, offsets, etc.
ing for grip.
08-15-2022, 05:39 AM | #12 | |
Easy description from the web: CCB is a disc made up by a core of ceramic material, reinforced with carbon fiber and covered by an additional ceramic friction layer on both braking surfaces. Ceramic Composite Material – CCM is made up by a core of ceramic material, reinforced with carbon fiber. In comparison to CCB, CCM disc braking surfaces are not covered by an additional ceramic friction layer. |
08-15-2022, 12:19 PM | #13 |
Who Needs to KNOW?
Yup - does appears to be the case. Bobbins are also different, potentially to prevent cross breeding
ing for grip.
08-15-2022, 01:46 PM | #14 |
Great in infos, thank guys!
If one would want to upgrade just pads and rotors of the ZL1 1LE front brakes (the copper brake system, not the newer copper-free RPO BCD system), which rotors and pad would fit? Would you have the parts numbers at hand for those? |
