07-25-2022, 07:59 AM | #1 |
Note to Track drivers
Just because ONE side of your brake pad has material, doesn't mean the OTHER side does.
I had 1.5mm on the thin side, yeah there's a little pad-taper. Moral of this story: Take your brake pads off to check depth
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
07-25-2022, 03:09 PM | #2 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Haha, I think I'm going to be right there with you when I get back from vacation and pull these 1st set of pads. Ran NJMP last week and probably should've pulled them to verify thickness.... I think I survived without rotor damage. We shall see.
07-26-2022, 09:45 AM | #3 | |
Okay, we'll see how cringe-worthy this post is with some pics
07-27-2022, 01:58 PM | #4 |
The pads in question...
07-27-2022, 03:45 PM | #5 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
You can get a good idea of the remaining pad thickness just by taking the wheels off and using a measurement tool like this at the top, middle, and bottom of each pad while it is still installed in the caliper.
https://www.amazon.com/gp/aw/d/B09X43JK7S/ They are also sold at Harbor Freight and auto parts stores but I recommend metal ones since the plastic ones will start melting within a few seconds if the brakes are still hot. |
07-27-2022, 08:13 PM | #6 |
