04-25-2022, 10:48 AM | #1 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Anyone know what this is?
Found this today next to the gas pedal. I recently had the clutch slave cylinder replaced. Maybe related to that?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
04-25-2022, 10:59 AM | #2 |
Petro-sexual
Firewall plug?
04-25-2022, 10:59 AM | #3 |
Petro-sexual
Or maybe around the steering column and trim?
04-25-2022, 11:12 AM | #4 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
That is the plug that covers up the bolt on the gas pedal mount to the floorboard. What do i win?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| Borla S-Type Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
04-26-2022, 05:31 AM | #5 |
My undying gratitude and you can drive my M6.
Mal
04-26-2022, 10:10 AM | #6 |
Was that what it was tho?
04-26-2022, 10:16 AM | #7 |
It looks like it. The bolt is exposed. It is supposed to be? But, I'll be damned if I can get that rubber thing to pop back in that hole. I tried a little WD40, but so far no go. Can you point me to a parts diagram?
Mal
04-26-2022, 11:53 AM | #8 |
The bolt shouldn't be exposed. Takes a little force because it shouldn't be easy to remove, I believe the "squared" side goes towards the pedal itself, it's fitted for the actual hole so try rotating it.
04-26-2022, 01:35 PM | #9 |
The rubber cover goes in with very little pressure, you probably oriented it wrong. Don't try to force it, it should just snap in.
04-26-2022, 01:57 PM | #10 |
That's what she said.....
Thread Tools | |
