01-26-2018, 11:21 AM | #1 |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
Front Seal Blown
Didn't quite make it a year. I was getting on her today and in high RPM's she started to make a smoke cloud. I got out of it and smoke went away. Car runs fine with no issues/noises. Took the below pictures and looks like a front seal?
*edited so people don't have to read the entire thread.* Seals blown because of ringland failures on two pistons. Rebuilt engine with a lower compression and other goodies.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
01-26-2018, 11:31 AM | #2 |
Yep, pull the balancer install and LS3 seal.
www.jannettyracing.com
01-26-2018, 11:39 AM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
And add more crank case ventalion.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
01-26-2018, 11:46 AM | #4 |
Yeah that too damn I type too fast LOL
01-26-2018, 12:24 PM | #5 |
Thanks for the quick response thanks. LOL.. Will do.
01-26-2018, 12:33 PM | #6 |
Drives: 2019 CTS-V Join Date: Feb 2016
That’s my biggest concern right now. How much boost were you running and did you have a oil cap breather to help vent the crankcase?
01-26-2018, 01:09 PM | #7 |
Running around 9-10 PSI with no added crankcase ventilation.
01-26-2018, 10:43 PM | #8 |
01-26-2018, 11:19 PM | #9 |
Mine did the same thing around 10psi.
I got what is suppose to be a ls3 seal but the part that rides on the balancer is a little smaller and I think it is way too stiff to stretch over. I wonder if they gave me the wrong seal.
01-27-2018, 09:16 AM | #10 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
To be on the safe side I run dual crank case vents.
1. My Mightymouse Solutions catch can vents to atmosphere from the valley port and 2. Metco one way valve cover breather that replaces your oil fill cap. Hope you're able to get the LS3 seal installed quickly.
01-27-2018, 09:43 AM | #11 |
SNSTRSS
Thanks for the info. Would you happen to have the part numbers? Would installing the Metco breather on a non boosted engine make any sense?
2016 Black Camaro 2SS A8 NP
01-27-2018, 09:49 AM | #12 |
We carry everything you need in stock give us a call.
01-27-2018, 02:46 PM | #13 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Product ID: MBR0003 Valve Cover Breather
01-27-2018, 08:04 PM | #14 |
That's the one exactly!.
Thread Tools | |
