Old 07-01-2024, 10:48 AM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
Are the performance gains the MSD has over a Ported LT2 worth it?
Im about to get ported OEM heads and the BTR 220 installed on my car. Ive heard the MSD is better for this setup but..... its super ugly to me. Im really big into keeping the engine bay pretty and with the LT2 IM you can have the cool looking engine cover and fit the CAMARO fuel rail covers on the side but MSD makes the engine bay look bad with everything on the sides exposed.
Was anyone able to make the MSD look good in the engine bay? would extra hp from the MSD over the LT2 even be noticeable?
The dream would be to keep the stock IM and engine cover and paint them or get them in carbon, but I know I'll be missing out on too much performance for that to be worth it. Really wish aftermarket IM designers would put some effort into making them at least a little less of an eyesore or designed them to still work with the OEM fuel rail covers.
Saberscar223 is offline   Reply With Quote
Old 07-01-2024, 11:27 AM   #2
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Heads and cam are where the MSD actually makes sense, but the LT2 is still a nice improvement. If you want the highest possible rev range, MSD is it. If you arent chasing every last horsepower high up in the rev range, LT2 will be perfectly fine for you.
Also, if you arent chasing times, I doubt the difference between the two would be very noticeable at all.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 07-01-2024, 01:00 PM   #3
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
So,,, does the ported LT2 bolt right in place without any modification?
KC64 is offline   Reply With Quote
Old 07-01-2024, 01:01 PM   #4
Saberscar223
I was planning on buying mine from GPI and they modify it to fit.
Old 07-01-2024, 02:22 PM   #5
GreyGhost702
Drives: 2019 Camaro 1SS1LE
The short answer is no. But Phastek sells a DIY modification kit with nice instructions. GPI will do the modifications for you for an extra fee. I enjoy the DIY challenge and do enjoy pinching the occasional penny. You can pick up the LT2 intake from Rockauto for $190. The cover is an extra $120, if you like max bling. I don't believe Phastek or GPI sell the cover, but I could be wrong, I know Phastek doesn't per conversation with a sales agent.
From what data I've managed to find on dyno results, porting produces marginal results, and no matter what you do you'll likely never be able to port match to a set of ported heads. As far as porting the inlet for the TB, it's designed for 87mm, but with an adapter you can bolt up the 95mm LT5. I suspect the gains would be marginal for NA, but if you're scratching for every last HP, the LT5 TB comes pretty cheap. But if you're paying to have the manifold work done, then it's really no sweat off your back.
The real PITA comes when you want to use the LT4 HPFP or similar, as you'll need an intake port spacer to lift the manifold higher due to clearance issues with the taller fuel pump. You already have to shave the bottom ribbing of the manifold to clear the fuel lines and LT1 HPFP. The LT4 is about 3/4" taller than the LT1.
I finally have my engine far enough to start dry mounting the pump and LT2 IM so I can get detailed pictures for my build thread. Since I'll be measuring pump lash, it'll be a good time. It drove me nuts for weeks because no one else seemed to talk about the LT2 on supercharged applications, but I suppose it's because there are so few of us using the LT2 vs the MSD or bigger.
2019 1SS1LE M6 Shadow Grey Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR Chromoly Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 07-02-2024, 09:15 AM   #6
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
SMGspeed has a Stage 3 ported LT2 available as well, has all the modifications done for one and done bolt on. (Excluding the LT4 HPFP thing)
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR5IX-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
Old 07-02-2024, 09:54 AM   #7
Slip3Kid
Slip3Kid's Avatar
Drives: 2023 Camaro 2SS
It is my understanding that the LT2 cover will not fit and will rub on the hood of the Camaro. I have been waiting for somebody to 3D print one up that would work but so far there is nothing that I know of.
23 2SS M6
1/30 1100
3/23 2000
3/31 3000
4/04 3400 TPW 4/17
4/19 3800
4/20 4300
4/22 5000
4/24 6000
Slip3Kid is offline   Reply With Quote
Old 07-02-2024, 11:47 AM   #8
FlukeSS
FlukeSS's Avatar
That is not true.
The intake that is a problem is the Hi-Ram intake that requires a hole cut in the hood or a COPO Camaro hood solution.
Old 07-02-2024, 12:00 PM   #9
Canyonero
Canyonero's Avatar
Drives: F-Series Canyonero
Originally Posted by FlukeSS View Post
That is not true.
I remember a couple threads where folks added clearance.
Example:
https://www.camaro6.com/forums/showp...9&postcount=19
There is another where someone else ground the front of the cover. Can't find it.
Maybe a difference with the facelift hood?
Edit: Another example
https://www.camaro6.com/forums/showp...&postcount=290
Canyonero is offline   Reply With Quote
Old 07-02-2024, 02:06 PM   #10
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Yes, when I ran the LT2 with the cover, the very front of it would rub on the hood. It put two little lines in the liner, but thats it. It won't hurt anything.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 07-02-2024, 02:25 PM   #11
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Do you have a link for the cover?
SSShark is online now   Reply With Quote
Old 07-02-2024, 08:16 PM   #12
FlukeSS
FlukeSS's Avatar
Example:
First link: He doesn't have a stock hood, so that's his doing.
Second Link: He's using a Corvette manifold cover. No vents on the hood either.
More than likely custom hoods and/or manifold covers.
Here's mine without issue. Yes I know the under hood is dirty :x Dirt signifies where all the magic happens.
Old 07-03-2024, 09:31 AM   #13
GreyGhost702
If you’re not racing in a fashion where every hp counts, I wouldn’t sweat the LT2 at all. The MSD is clearly the better performer, but at its price point is it worth $1,000 difference for roughly 10-15hp peak? If the LT2 gets you to 500whp NA, and the MSD gets you 510whp, that’s worth about 1mph trap in the 1/4 mile, or less than .1 E/T, on paper. Seat of the pants, I don’t think you’d even feel it. I am eager to get the LT2 under boost and see how it breathes.
Old 07-03-2024, 02:50 PM   #14
s346k
s346k's Avatar
Drives: like an old lady
imho for a bolt on car, no. cam or heads cam absolutely.
shaving and painting the msd makes its appearance bearable. i've had 3 msd manifolds and 2 of them were shaved & painted (also ported by mamo).
