02-09-2021, 07:20 PM | #15 |
My note 10 plus would be connected to my 60 inch LG TV because my wife and daughter watch WWE and I watch CBS All Access using a HDMI cable for Android phones to smart tvs. But have not use the new phone yet like that, s21 ultra.But we did discuss at the dealership today about the rexing dash cam that is hardwire. As I told the service manager the dash cam was installed by best buy in April and this problem started in late November. He said no problem but that they will check into that too.
02-11-2021, 04:37 PM | #16 |
As my camaro is in the dealership for yet again infotainment system issues I had the pleasure of a 2021 Chevy Blazer loaner. I was pretty impressed by the loaner, great on gas, roomy and had more pep then I thought. But I decided to connect my phone using the USB cord and I was surprised it didn't work like in my camaro. As I was trying Bixby kept trying to turn on and it did the same thing in my camaro after the last update on my old phone. So I stated to think could Bixby be interfering with Android Auto? It wasn't easy to disable Bixby but I got it done, so after work I again connected my phone to the USB in the Blazer and it connected immediately. Everything was working as it should. On my way home the dealership call me and told me that the infotainment system is working as it should as they have connected several different phones. When I arrived at the dealership they went through all the steps with me and now everything is working as it should. Could it have been Bixby all along conflicting with Android auto hard to believe?
02-11-2021, 07:33 PM | #17 | |
Hot Camaro
Could it have been Samsung's apps? Absolutely. Seems you might have this figured out, and great for you if you do. Just troubleshooting this sort of stuff takes way longer than it should! |
02-11-2021, 08:55 PM | #18 | |
02-13-2021, 01:43 PM | #19 |
I agree, to many apps are now pre- loaded on these phones when you get them and many of them can't be uninstalled, but at least they can be disabled. But now when I start my camaro up I use to just connect first thing with my usb cord for Android Auto and everything work now I have to first connect with Bluetooth then the USB cord, I believe it also has something to do with Android Auto last update and it really mess everything up. I believe that the Ford F-150 is having big issues with there Wireless connection and Android Auto is supposed to have a fix coming out in March along with a 6.1 update.
02-26-2021, 08:57 PM | #20 |
After my 3rd visit to the dealership for infotainment system issues here is what happen. Radio was replace, and even after that the mechanic still couldn't get the system to update. On the invoice it says: system refuses to still update or accept command. Now, Bluetooth works just fine until I connect with the usb-c cord to Android auto to use Google maps and voice to text. With voice to text there is no voice command and Sirius XM no sound unless I switch back to Bluetooth and play a song from YouTube then switch back to Sirius XM then the sound is back on. Service manager told me everything is working as it should and that other phones where connected and no problems but I never witness it. Does anyone know of a good stereo shop or someplace that's Specializes with these problems that are located in Pittsburgh. I keep getting told by others that the update takes time but it's been over a month. Getting frustrated with this thinking about the lemon law.
03-17-2021, 10:10 AM | #21 | |
11-24-2021, 06:21 AM | #22 |
Final update, if anybody has the same problem with the random P0700 code. It is the wiring harness in the transmission pan. The temperature sending unit goes bad which causes the CEL. Part is $90 but you have to drop the pan to get to it and refill with fluid.
11-24-2021, 07:52 AM | #23 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Just had this exact service performed with full flush. Temperature sending unit tripped the code.
Kindness and compassion #OthersFirst |
11-24-2021, 08:43 AM | #24 |
I bought a hand held scanner so I could just erase the code when I got the CEL. Hand a couple of extra dollars and got it fixed so I did not have to worry about it anymore.
11-24-2021, 09:55 AM | #25 |
11-24-2021, 10:09 AM | #26 |
Thought it would help somebody else out that was having the same issue. Happy Thanksgiving all
11-24-2021, 12:47 PM | #27 |
Drives: Camaro Super Sport, Six on the Stik Join Date: Jul 2021
What Is The Cause Of P0700?
The vehicle should avoid being driven when presenting with the trouble code P0700. It could get caught in one gear and cause not only a safety hazard for you, but for those around you as well. Code P0700 Common Diagnosis Mistakes Diagnosing concern as an engine misfire or internal transmission problem before testing and looking at freeze frame data. |
11-24-2021, 01:48 PM | #28 | |
But now that the temp sender has been identified as a possible source, it would not surprise me if this ends up being the MOST COMMON cause of p0700 on a 6th Gen Camaro. |
