09-23-2020, 09:26 AM | #1 |
Tire pressure - Car's info screen versus gauge press.
Has anyone else seen where the tire pressure shown on the car's info screen is 3# less than that on a conventional pressure gauge?
'20 ZL1 1LE A10,
09-23-2020, 11:42 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Mine are usually within ±1 psi of what I measure with a decent oil-filled Longacre gauge, on rare occasions up to 2 psi off. How confident are you in the quality of your gauge? If it's a cheap stick gauge I'd trust the monitor, but if the gauge is decent and you trust that it's working correctly then I'd trust the gauge. 3 psi off isn't necessarily terrible but it would make me double-check my gauge since it's about a 10% difference.
2017 SS 1LE.
09-23-2020, 11:54 AM | #3 |
Drives: 2020 SS Join Date: Aug 2020
Yes, mine read low enough to get the warning at times and the dealer overfilled the original tires by 5 pounds. Anyway, I put on new wheels/tires/sensors and filled each tire to 35 lbs before installing. When I programed the sensors to the car, the psi readings have been more accurate.
Now all of that said, sometimes the car sits for a few days, when I check the psi via the app the psi is always changing. I'm guessing it's the temp of the garage and/or our altitude?
2020 2SS
09-23-2020, 12:05 PM | #4 |
I took off the Goodyears and put on Michelins last week, which is when this problem began. Do I have to reset some data point here?
'20 ZL1 1LE A10,
10-03-2020, 03:27 PM | #5 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Perhaps the tire/wheels got switched side to side when the new tires were installed. If not reprogrammed, the right tires showing in the DIC will be on the left side of the car
10-03-2020, 06:37 PM | #6 |
Who Needs to KNOW?
Very close.. esp over time. AUtox.. when you adjust every run or two.. takes few minutes to average out the new reading.
ing for grip.
10-06-2020, 01:12 PM | #7 |
My sensor monitoring results are always within 2 psi of my digital pressure gauge.
It is hard to know the exact correlation because the car reports whole numbers and the gauge reports in increments of 0.1 psi. I don't know if the car reports 34.6 as 34 or 35. |
10-06-2020, 01:21 PM | #8 |
Mine is always 2psi lower.
10-06-2020, 02:00 PM | #9 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
Mine seem to be very close, at least within 1 PSI. Close enough for daily driving. I don't have sensors in the autox wheels since I'd be checking those with a gauge anyway.
10-17-2020, 12:02 PM | #10 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
10-17-2020, 12:51 PM | #11 |
The differences on mine are within ±0.5 psi between the TPMS sensors and the manual gauge, maybe I just got lucky with the sensors.
I will say that the tires build temperature following different paths, even if their cold pressures are equal, a 1-2 psi difference is displayed while getting heat into them during the first couple of miles, but when warmed up, pressures are very close (displaying equal) again. Makes sense if I consider that tires are unlikely to be experiencing the same exact amount of load while driving on the street.
