Old 04-16-2018, 08:23 PM   #1
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Flowmaster American thunder question.
This may be a stupid question. But here goes.
I have the American thunder dual exhaust for non npp exhaust. Is it possible to add another outlet to turn it into a quad tip exhaust? I'm getting the rear diffuser for the quadtip system and I'm not going to spend another $500 to $800 on a new exhaust. Any suggestions or ideas?
Old 04-16-2018, 09:20 PM   #2
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
Like this?
2016 Chevrolet Camaro 2LT RS
• Edelbrock E-Force Stage 1 Supercharger • Custom tune by Overkill Motorsports • AFE Momentum GT Pro Dry Cold Air Intake • MBRP SS Cat Back Exhaust • iROC-z Wheels • Nitto NT555 G2 Tires (275 fronts, 305 rears)
dgriff14 is offline   Reply With Quote
Old 04-16-2018, 09:45 PM   #3
chris227
chris227's Avatar
Yes and no. The angle of the tip on my exhaust is small and quick and is not in the right position to just add a dual tip. Just trying to get ideas on a way to get quad tip without buying a new one. This is what I have.
Old 04-17-2018, 03:17 AM   #4
dgriff14
waddupdgriff
dgriff14's Avatar
Ahh, I see. I’m actually in the same boat because I want the quad tipped MBRP Exhaust but I already have Borla Atak on mine that I’m thinking of reselling. Wish I could’ve helped but good luck!
Old 04-17-2018, 07:53 AM   #5
Nsxmatt
Drives: 2017 Camaro
Well you could sell your current exhaust so you'd only be out of a couple hundred dollars the most. IMO the flowmaster is best sounding exhaust out there so you shouldn't have any problem selling it.
Nsxmatt is offline   Reply With Quote
Old 04-17-2018, 11:34 AM   #6
chris227
chris227's Avatar
Thought about that, just don't want to get a new one. gonna go by a muffler shop and see what can be done to add the second tip. I want it to be functional. Not just a tip. I was thinking i could just cut the pipe off and have a new one welded on at the correct angle and weld on a dual tip. Probably the simplest solution right there.
Old 04-18-2018, 03:56 PM   #7
Tech@Flowmaster
Tech@Flowmaster's Avatar
Drives: 2016 Camaro SS
Due to the lack of additional room in the rear of the Camaro you will need to go with a much shorter than conventional exhaust tip. The exhaust tip that is included with the American Thunder Axle-back is 5.25" in length. We offer a dual exhaust tip that just may fit. This is a weld on style, stainless steel tip with a 3.50" outlet. It fits 2.50" piping and measures 6.75" long by 7.50" wide. You can click on the picture below for a link to the item or you can give us a call at 707-544-4761 for additional information.
-Jason @ Flowmaster
Tech@Flowmaster is offline   Reply With Quote
Old 04-18-2018, 04:59 PM   #8
chris227
chris227's Avatar
-Jason @ Flowmaster
Thanks for the info. Just got back from the muffler shop and am dropping the car off monday. Got it figured out. Thanks for all the help.
Old 11-02-2020, 09:36 AM   #9
Jaystroh
Jaystroh's Avatar
Drives: Camaro RS 2LT
Hi old thread I know but was curious how the muffler shop switched your single tip into quad and what style tips they used to do it? I am switching my rear diffuser to quad ikon motor sports one and would like to tell my exhaust guy what works since I have the single tip set up. Thanks for any help.
Jaystroh is offline   Reply With Quote
Old 11-02-2020, 06:49 PM   #10
chris227
chris227's Avatar
Had mine done on my 2016 Camaro, DO NOT Cut a hole and add a second port. Terrible drone from hell. I had it done, then quickly turned around and had the hole welded up inside the new tips.
