01-02-2020, 04:25 PM | #1 |
Drives: 2017 50th Anniversary 2SS Coupe, M6 Join Date: Apr 2017
ZL1 1LE Winter Tires
Can I please get a suggestion on what size winter tires to use on the 2020 ZL1 1LE , as I plan on driving mine through winter on those clear days once I take delivery
2017 50th Anniversary 2SS Coupe | M6 | Special Fifty Wheels | MRC | NPP | Sunroof | Special Fifty Grey/Black/Orange Interior/Trim | Chevy Black Bow Ties | Ceramic Pro Gold Lifetime Package | Husky Floor-Liner | Thinkware F770 Dual Camera Dash Cam | ZL1 Add-Ons Red Lift Points |
01-02-2020, 08:30 PM | #2 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
There aren't any that fit the OEM size.
The best you can do is an "all season tire" in 305s on all four corners. If you get a second set of wheels that are skinnier, then you can get narrower tires.
01-02-2020, 08:48 PM | #3 |
Drives: 2018 ZL1 1LE Join Date: May 2019
it might be cheaper to actually buy a winter beater.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
01-02-2020, 08:48 PM | #4 | |
Suggestion?
01-02-2020, 08:49 PM | #5 |
Romans10:9-13
Seriously this.
01-02-2020, 08:52 PM | #6 |
Romans10:9-13
any 5th gen or 6th gen SS car with 20" will work. I say the SS only due to them being able to clear the brakes. then to keep the same tire diameter it needs to be a 245/35r20
Search forsale section this is a good tool to help https://tiresize.com/comparison/
01-02-2020, 09:09 PM | #7 | |
Drives: 2019 Satin Steel Metallic ZL1 Join Date: Jun 2014
MICHELIN Alpin PA4 winter tires…The front are 275/30/20 and the back are 295/30/20 They do make the size needed for your ZL1 LE https://tiresize.com/tires/Michelin/Pilot-Alpin-PA4.htm Expensive, but fit right on stock rims... I am in Winnipeg, they are amazing, no problems... |
01-02-2020, 09:30 PM | #8 | |
Romans10:9-13
he could buy the "normal ZL1" wheels and then use those sizes in a 20" wheel.
01-03-2020, 12:53 AM | #9 |
That's not an option
01-03-2020, 12:57 AM | #10 |
I have a spare set of SS 20 inch wheels, could I run a squared set up with that? Or do I still need staggered?
01-03-2020, 06:16 AM | #11 |
Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
The ZL1 1LE rims are 19x11 Front and 19x12 Rear
01-03-2020, 06:46 AM | #12 |
Romans10:9-13
01-03-2020, 06:55 AM | #13 | |
Romans10:9-13
You can run the same size tire on the wheels as long as you check the manufacturers requirement on Rim size. Which means you have to choose a size that fits with, which isn't hard to find. BUT IF THE WHEELS ARE DIFFERENT WIDTHS AND DIFFERENT OFFSETS, YOU STILL CANT ROTATE THE TIRES. JUST WANT TO MAKE THAT CLEAR. people think differently when you say a "square" setup
01-03-2020, 01:26 PM | #14 |
Drives: 2016 Dodge Charger SCAT Join Date: Jul 2019
This is actually why I'm not getting the 1LE package on mine...when I trade in the SCAT charger...I live near ATL, so we do get cold weather. I couldn't find a decent tire for the 1LE that would work in the winter, or all-seasons.
