08-14-2018, 10:03 AM | #29 |
Retired from Car mfrs....
we are lucky that the chevy minder works on time, honda does not , and a guy on their forum hasnt changed his in 2.5 years because the minder still says 35 pct.....LOL
08-14-2018, 10:32 AM | #30 |
Thank you Al Oppenheiser!
Shirley you must be joking!
It was a gal, not a guy. https://en.m.wikipedia.org/wiki/Shirley_E._Schwartz |
08-14-2018, 11:46 AM | #31 | |
Drives: Camaro 50th anniversary edition Join Date: May 2017
And I am not sure if you let your car stay for a year that it show 0%. As long as the car stays dry I could imagine that the life count goes on again at about 30% maybe.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
08-14-2018, 11:48 AM | #32 | |
In the United States it will show zero after year. I've seen it. Happened to me in 2016 where I left my car in storage for four months during the summer. And in the United States, BMW has gone to a 7000 mile interval change, used to be 15, as They found they had oil problems at 15.… |
08-14-2018, 12:11 PM | #33 |
Drives: 2017 Camaro Join Date: Mar 2018
Hondas do work off of time also. Just not a set year amount. I've worked for Honda for over 15 years.
08-14-2018, 12:15 PM | #34 |
Ok, I didn’t know. I use my car only from April to October. When I put my car to sleep end of October the oil showed around 70%. In spring (April) it shows around 30% and now in August 10% when I went to the service. That was the reason I came up with the idea that it will maybe recover after awhile. Normaly we change oil after 30k km.
Soleil
08-14-2018, 01:31 PM | #35 |
I wouldn't run a direct injected motor much past 5k miles on a oil change regardless of what the OLM says.
2016 NFG 1SS A8
08-14-2018, 02:57 PM | #36 |
Drives: 2018 HOT WHEELS SS 6 SPEED COUPE Join Date: Jun 2018
I AGREE, I CHANGE OIL MYSELF AND I WOULD NOT RUN ANY ENGINE OVER 6K MILES. I JUST CHANGED OIL IN MY 2011 6.2 SILVERADO AT ONE YEAR, WITH 3300 MILES ON THE OIL, FULL SYNTHETIC. THE OLM WAS AT 75%.
2017 QUICK 16 TRACK CHAMPION
STATE CAPITOL RACEWAY RACE TRACK CHAPLAIN FOR 30+ YRS |
08-16-2018, 10:11 PM | #37 | ||
Drives: 2011 Camaro 2LT/RS Black Join Date: Nov 2011
Here's why: https://www.waynesgarage.com/tips/mo...much-about-oil Quote:
08-16-2018, 11:35 PM | #38 |
what would being a DI engine have to do with motor oil?
08-17-2018, 04:36 AM | #39 |
Not sure whether it's the DI engine, or how the DI engine is driven. Boosted DI even more so, it seems. After seeing what 3200 miles did to the oil in my Z, I would give that <5k philosophy some merit.
Compared to my DD, my Z gets far more spirited treatment. Both get full synthetic. My DD is a NA 4.6 port injected v8, and it's oil is still somewhat amber to light brown at ~10k miles. But while Z's recent Blackstone labs report came back good at 3200 miles, damn that oil was jet black! |
08-17-2018, 12:08 PM | #40 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
If your oil is getting dirty fast, that can be a sign that your air filter is garbage at actually filtering. Most people who are not using paper filters would fall into this category. Though, DI is always going to put a bit more dirt into oil vs older style where some of that dirt gets sent out the tailpipe.
I use full synth and change the oil about twice a year. That amounts to about 5k miles for me. Due to fuel contamination from DI, I wouldn't push it much past 5k even if you had a paper filter. So is full synth overkill since you're dumping it out way before it's had a chance to really degrade any less than conventional? maybe, but i haven't even thought of conventional oil as an option to use in cars basically since i started driving. |
08-17-2018, 05:20 PM | #41 | |
Drives: 2016 Z06 coupe Join Date: Dec 2016
08-17-2018, 07:05 PM | #42 |
Drives: 2017 RS Garnet Red Tintcoat A8 Join Date: Oct 2017
My son's 17 RS V6 A8 was down to 16% so I took it to my friend's shop (has great business - Mustang Cobra guy) today for 2nd change (closest Chevy dealer is in Tupelo, Ms). The car had sat on a lot in Arkansas for approx 400 days, June 16 build. My dealer in West Point, Ms., picked it up for us on the transfer and it had 602 miles on it when we bought new and drove it about 75 miles home. Oil life was about 20% so he changed it with synthetic then. Today, he checked the sticker, only 2400 miles on oil, but 4 months since initial change. He said the oil looked great and reset the monitor. My son, a Sr in HS only drives it 10 miles round trip to school daily. He and I stretch it out a little on weekends. Will let Chevy change it, 27? pt inspect, and rotate tires on his fall or Christmas break when we are off. Mileage should be around 6K by then. I appreciate the advise on this thread and the honesty and help from my local shop.
