04-01-2015, 01:13 PM | #71 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
04-01-2015, 01:26 PM | #72 |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
Doesn't power come with efficiency?
04-01-2015, 01:31 PM | #73 |
Drives: 2010 Camaro LT2/RS Join Date: Apr 2011
Too bad Chevy doesn't have an AWD car. This would be a perfect candidate.
04-01-2015, 01:49 PM | #74 |
Moderator.ca
Usually that only happens when you increase the compression ratio. For most other things, its one or the other.
Once you near the pre-ignition limit for an engine, you essentially have to do wasteful things with the fuel in order to keep the engine happy. Tuning the engine for a lower power target lets you waste less gas.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
04-01-2015, 02:01 PM | #75 | |
Drives: 2012 45th Anniversary SS Coupe Join Date: May 2012
04-01-2015, 02:39 PM | #76 |
Drives: CTS-V Join Date: Aug 2008
Much much much better .
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
04-01-2015, 03:07 PM | #77 | |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
04-01-2015, 03:27 PM | #78 | |
04-01-2015, 03:31 PM | #79 | |
Drives: 21 Bronco Join Date: Jun 2012
250K is the sales goal? That is quite the goal, last year they only sold 188K Malibus. even the year before was 200K. I don't think its going to gain 50-70K in sales in one year, maybe in a few but not the first. Like otehr have said the public needs to see how good of a car it is before it starts climbing in with the big boys |
04-01-2015, 03:55 PM | #80 | |
Moderator.ca
It is common to use a rich fuel-air mixture to cool down the air charge, making it less prone to pre-ignition. Tuning your engine so that the air charge isn't as hot (by lowering boost or easing off on the compression ratio) lets you lean out the mix a little bit. When you do that, you get less power but you waste less fuel in the meantime. BMW is supposed to be introducing a new turbo engine that uses water injection (under certain circumstances) in order to improve the fuel economy (and possibly emissions too) by not having to use as much gasoline to achieve the same air charge temperature. With cam profiles, a high performance cam has more overlap. That means that both the intake & exhaust valves are open at the same time. Inevitably, this leads to unburnt gasoline exiting the cylinder -a complete waste of fuel.
04-01-2015, 04:37 PM | #81 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
Looks like a winner to me. Huge improvement over the current model from what I can see.
04-01-2015, 05:02 PM | #82 |
Drives: 2012 Ford Focus Join Date: Jan 2014
Digging the side profile and rear end.
The front end though looks a lot like a larger refreshed Cruze which is no bueno IMO. |
04-01-2015, 05:16 PM | #83 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
Don't care for the front end styling. Impala looks much better. Everything else is impressive.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
04-01-2015, 05:52 PM | #84 |
N7 Spectre
Drives: 14 ATS Performance 3.6L AWD Join Date: Jul 2008
Wow! What a hot unit! If Chevy did this good with the Malibu, they should hopefully hit it out of the park with the Camaro!
