08-05-2022, 12:09 PM | #1 |
Drives: 2017 2SS Camaro Join Date: Mar 2015
Clicking sound in rear end
Hi All,
I have noticed a clicking/clacking sound in my rear end when driving slow. it is most noticeable when creeping around parking lots. it sounds like a clicking CV joint. It happens randomly from side to side. If I pull forward 15FT and Back up 15Ft the clicking happens around the same spot. Straight or turning, it doesn't matter, however it happens more when swerving or parking. I have read all the "axle click" searches and checked my mounting surface on the rotors and re torque my axle nuts accordingly. However, I am lost where to go now without having to pull an axle. I have to apologize to BMR as well as I threw them under the bus when this first started. I chalked it up the the toe rods and end links without being fact based. I had me 250LB buddy bounce on my trunk aggressively and there was no clicking or squeaking to be heard.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
08-05-2022, 12:27 PM | #2 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Have you replaced your LSD fluid? There is an additive in the fluid that is supposed to eliminate that noise. It usually comes in the fluid now but it also sold separately.
https://www.summitracing.com/parts/a...IaAgkmEALw_wcB
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
08-05-2022, 12:37 PM | #3 |
By the way, this stuff had a huge drop in price. I had to pay $26 per quart about 5 weeks ago. Down to $14.40.
08-06-2022, 09:14 AM | #4 |
Hot Camaro
That's the fluid I used in my SS/M6 - I didn't add anything to it as I don't have the eLSD and have had zero issues since the change (all 7,000 miles of it - lol).
When I bought it two years ago, it was $22/quart. I'm considering buying a couple of quarts at this price just to put it on the shelf. |
08-06-2022, 09:33 AM | #5 | |
Gas/diesel prices have come down quite a bit, shipping costs are much lower now.
08-06-2022, 09:38 AM | #6 |
Hot Camaro
The $22/quart I paid was long before the major jump in prices, though. At the time I bought the diff fluid, I was paying about $2.159/gallon for premium (Aug/Sep 2020). Current gas costs (now that it has come down a bit) are about $4.599/gallon.
08-06-2022, 09:47 AM | #7 | |
...that said, I still warmly welcome the recent $1/gal drop in gas prices.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-06-2022 at 07:25 PM. |
08-06-2022, 10:00 AM | #8 | |
Hot Camaro
And, like you, I appreciate the costs coming down but still feel like they are WAY higher than they should be. |
08-06-2022, 02:27 PM | #9 |
well I have officially exhausted all my options. Axle Bolts tightened (passenger side was backed off half a turn and could turn with my fingers) and re torqued to 199FTLBs, no excessive play in bearings, cleaned the rotor and wheel mating surface and changed the diff fluid to RP synthetic gear.
It has little improvement. Only thing I can think of now is it is the CV joints in the axles. Anything i'm missing here? it is really quite bothersome knowing there is something not right. I have a 1500KM remote trip planned coming up on Thursday and I would really like to ease my mind. Everything looks great.
08-07-2022, 03:41 PM | #10 |
Update: (incase anyone needs to know the n the future)
So after all this, it turned out to actually be the BMR toe rods. So now my question is, for all of you that have these, what are you all using to lube them? I ended up using some Loctite anti-seize. I didn’t have any lithium grease left and this was my next best choice. Now I’m going to add this task to my yearly diff service. Which judging by the pictures needs to be done at least yearly. Even the top fill plug was thick.
08-08-2022, 03:11 PM | #11 |
Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
Sounds like you found your issue but you may also want to check the rear axle half shaft bolts that have been updated:
https://www.camaro6.com/forums/showt...le+half+shafts
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
