Old 07-15-2021, 08:50 PM   #1
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
DYI Painting - Side Skirts
Has anyone purchased unpainted side skirts and DIY paint them? cant seem to find much in the search tool or via google.
Any suggestions? Do I try and wrap it myself?
TIA
eaglesfan2006 is offline   Reply With Quote
Old 07-15-2021, 09:11 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Z28pat did and here is the discussion.
https://www.camaro6.com/forums/showt...=561772&page=3
Old 07-15-2021, 09:25 PM   #3
eaglesfan2006
thank you for this! Exactly what I was looking for.
Old 07-16-2021, 08:04 AM   #4
ember1205
Hot Camaro
ember1205's Avatar
The painting should be reasonably straight-forward and be like painting pretty much anything else...
Sand, fill, sand, fill, sand, etc. until it's perfectly smooth. Then prime to find where it ISN'T smooth and repeat.
Once the primer looks right, multiple sprays of a thin layer to build up depth and protection. If you're going for a gloss look, a light wet sand between layers will help add depth to the appearance. Clear coat when you're done, wet sand, polish, and install.
To me, the installation is the much harder part. These things are like seven feet long and consist of flat surfaces and hard angles that are intended to mount up against a curved, contoured area of the car. Plan to do a lot of dry-fitting and understand how/where to tape and get them to adhere.
If you're interested, here's some install videos:
https://youtu.be/S_gmNJS1HyA
https://youtu.be/lVVQUBYoj5Q
https://youtu.be/JCtE-gw-fes
