02-03-2021, 01:18 PM | #15 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
02-03-2021, 01:23 PM | #16 |
So easy to test it...launch from a stop and go through all the gears aggressively....well at least through 3rd gear....any higher and you will be in triple digits. If no slip it should be good.
02-03-2021, 04:48 PM | #17 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I have heard that usually you test a slipping clutch by putting the car in higher gears and depress the gas a bit when cruising. Supposedly that's when slippage will become more apparent. Not sure if it's true, as I have never had issues with a slipping clutch myself.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
02-03-2021, 05:08 PM | #18 |
my cavalier had over 100k still on stock clutch and my cobalt ss had over 75k and still on stock clutch lol never actually replaced a clutch in any of my cars
02-04-2021, 09:19 AM | #19 |
Drives: 2015 Camaro 1SS L99 Rs Package Join Date: Sep 2015
Good news it sounds like it's not fried after all , it sounds like it might have taken some life off but it's still doing ok, actually it's funny cuz it feels a little firmer than it did before almost like I burnt it in or something, but yeah no more uphill stop and go like that that was retarded, that's what happens when it it snows in SoCal, everyone under the sun wants to go up and see at the same time, I'm bringing the wife's auto next time around
02-04-2021, 10:42 AM | #20 | |
If you heat it up too much you risk glazing the clutch/flywheel. It takes a lot of heat/abuse to do that, so I think you are fine. After a few weeks of normal driving, you can give it a little test. Get it up to like 40 mph in 4th gear, then give it some gas. If the rpm's shoot up and the car lags you have slippage. You don't even need to do this if everything seems fine (no slip). But if you are loosing sleep over the possibility of glazing, this should ease your mind. |
08-06-2022, 11:22 PM | #21 | |
Drives: 2020 Chevrolet Camaro 1LT 3.6L supe Join Date: Jan 2022
Trans sucks in mine too.
Frankly, you did good getting it to 30k on one clutch Going uphill in the mountains in stop snd got is not a good place for a clutch failure. I smelled ot in mine at 3700 miles, replaced everything OEM....and my clutch is giving me h**l again. I am putting an HD XTS clutch with a heavy duty pressure plate to make up for the 1/15th of an inch defect between the clutch and the flywheel causing a lack of pressure against it and the clutch. Are you aware that instead of sharing the master cylinder with steering and brakes, it is now shared between the brakes and the clutch. Turning off trac and stab ctrl. By pressing trac off for 10 secs it also turns off b4nn,h and press$$"çure plate that will have it's own fuid. $399 for it, plus $1000+ to install. B: Just trade it as is for a Jetta GLI, Civic Si, Kia Optima turbo....or even a Honda Accord Sport turbo. You will need to clear any codes with a OBD2 code reader and reset and clear any MIL'S. A Lainch brand Code or Creader is cheap, portable, and will clear the codes . Yeah...I love my little LAUNCH Creader 3001 2022 version Its like $25 including shipping and tax. |
10-24-2022, 07:00 PM | #22 |
Drives: 2020 1SS 1le Join Date: Apr 2019
These clutches will hold the power but they won't last if you track them and drive hard a lot. A lot of people have had clutches go around 20-50k miles even not driving hard. They are hit and miss on top of that the throw out bearing sits in a plastic housing and it feels like trash and has many premature failures. I def won't be putting OEM clutch in. I'll go aftermarket throw out bearing maybe ACT or one of the other good brand clutches.
