dave@hennessey
Old 03-07-2020, 04:18 PM   #1
Jace1999
Drives: Camaro 2ss
Any suggestions on stronger rear axles?
Mods. Stage 3 cam ,Long tubes, cold air intake , 18x10.5 with 305 drag slicks. Just broke one of my stock axles and am looking to upgrade to someone stronger and has greats reviews.
Jace1999 is offline   Reply With Quote
Old 03-07-2020, 04:26 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Have you done any suspension mods to help curtail wheel hop? Driveshaft Shop and Geforce seem to both be reputable companies to source axles.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-07-2020, 04:38 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
Driveshaft shop!
might want to get a new rear and driveshaft while you're at it
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 03-07-2020, 04:45 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
try some toe links and trailing arms while your at it from BMR as most do...…….
christianchevell is offline   Reply With Quote
Old 03-07-2020, 06:34 PM   #5
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
ZL1 hardware is also very stout.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 03-07-2020, 06:41 PM   #6
Slammed1000
Drives: 2011 2SS RS
Auto or stick? Stock can last really well if you take care of them. Offset bushings and if you're a stick car preload the gear before launching with the ebrake. Stock on a auto can go easy into the 9's
Slammed1000 is offline   Reply With Quote
Old 03-07-2020, 06:53 PM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
The 1le axles direct fit and have larger cvs on the outside. Get rid of wheel hop and you shouldn't break axles
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 03-07-2020, 08:59 PM   #8
Vegas Bound
Drives: 2013 Sparkly Red One
750+ whp with ZL1 diff and axles, no problems over 100s of passes.
Vegas Bound is offline   Reply With Quote
Old 03-09-2020, 06:36 PM   #9
fireman1153
Drives: 2010 Camaro SS
The ZL1 stuff is great if you're ready to swap out everything but the driveshaft shop makes great axles if you're not looking to swap diff and all yet. Just know that once the axles are beefed up, the diff or driveshaft is next if not addressed. Kinda depends on what power level you ever plan to get to as well. I have a built Tick perf trans, 3.5 inch alum. driveshaft, strange s60 diff and 1400hp driveshaft shop axles and can launch at 5k rpm with over 900hp to the wheels. You just need to make sure you build it to match your power output.
fireman1153 is offline   Reply With Quote
Old 03-09-2020, 08:12 PM   #10
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
I've been running DSS 1000hp since I broke a stock one, no issues at all with them. I should have done them when I did the Tru-Trac and 3.91's.
The tru-trac/3.91's/DSS axles/uprgraded diff bushings can be had for about 2K, compared to the 5K-6K cost of the ZL1 rear/axles.
If your car is 60' @ 1.5X or lower you'll need to upgrade both the differential and the axles.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 03-10-2020, 08:25 AM   #11
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
lpw cover stops stock case flex, trailing arms, 1le axles are a intermediate upgrade.
from your pic the outer cv blew up...1le outer cv is larger/stronger....also means you are having wheel hop...
also what kind of alignment? rear can be adjusted so you get better contact patch on launch when the rear squats.
good luck!
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
