05-10-2017, 05:45 PM | #29 | |
Drives: 2017 ZL1 Join Date: Mar 2017
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325) Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq |
05-10-2017, 06:00 PM | #30 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
I'm surprised the dyno had issues keeping the car planted. I've had friends with '03 Cobras making +600 rwtq without issues on the dyno. Also, just another variable, even how tightly the car gets strapped down effects the reading on the dyno.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
05-11-2017, 06:54 AM | #31 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Sure wish other ZL1 owners would post their stock dyno runs. Maybe it's just too early with the bulk of 2017 ZL1s being build 1st half of this year. Most of the other pulls I've seen had only a few hundred miles on them. I got mine last week of December and had about 2200 miles on this dyno pull. |
05-11-2017, 07:58 AM | #32 |
Mine is going back for another run on Friday night (mustang dyno). Its only done about 1000 miles so far
05-12-2017, 09:37 AM | #33 |
Cal
You may want to wait a while longer if you want a good, representative baseline. If you haven't been loading up the motor much the rings may not have fully seated yet. If you follow the GM recommended break-in this may not occur until after your 1500 mile period when you've taken it to the track a few times and/or had a few dyno pulls.
05-12-2017, 03:08 PM | #34 | |
05-13-2017, 07:43 AM | #35 |
As an update my Z made 500 bhp and 499.2 lbs on the mustang dyno of which we can all agree puts out around 15/18% less than a dynojet so to save me going to find one the conversion to match everyone else's dynojet readings it works out to 570 bhp and 528 lbs
05-13-2017, 08:35 AM | #36 |
Drives: 17 ZL1 Join Date: Mar 2017
I think I'll stick with the 12 to 15% drivetrain loss theory. So, with that said 570 is within reason. My guess would be the manuals are closer to 12% and the autos 15%. If your dyno results are close to these estimates your most likely in line with what would be expected, not 100% accurate but a fair baseline.
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
05-13-2017, 09:10 AM | #37 |
Cal
Did you get a print-out or screen shot that shows correction factors and smoothing, or maybe you jotted them down? I assume the Mustang dyno also has these parameters.
05-13-2017, 10:04 AM | #38 |
05-13-2017, 10:16 AM | #39 |
05-13-2017, 10:37 AM | #40 |
Cal
I was just wondering about the CF and smoothing factors. If you could get them off your printout and post them I can add them to the running tally table.
I've added a table to the end of my original post to keep a running tally of dyno results. I'm going to updated it whenever I learn of a new dyno run for the M6 or A10. If you still want to insert an image, here's how: Forum photos fit better on the page if they're no larger than 1024 pixels wide. I usually resize mine before uploading. Go to "Advanced" editor. Then scroll down to click the [Manage Attachments] button. When the attachment manager dialog opens, click one of the [Browse...] buttons. Navigate to wherever your scan or photo image is stored and select it. Then click [Open] Now you can click the [Upload] button and close the attachment manager. Click inside your message where you want the image to appear. At the top of the advanced editor you'll see a paper-clip icon. Click the paper-clip and select the image name to insert. You'll see something like this in the editor: [ATTACH]872053[/ATTACH] If you click the [Preview Post] button you'll see what your message looks like with the photo. If you click [Submit Reply] it'll be posted. --Cal |
05-13-2017, 11:13 AM | #41 | |
05-13-2017, 12:02 PM | #42 |
we can see it....
