Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 02-28-2020, 10:12 PM   #1
Brodie douglas
Drives: 2010 Chevrolet Camaro v6
2010 v6 camaro 6 speed fuel pressure
Hey just wondering what my fuel pressure should be at my code reader is reading 455 psi I have a v6 with a dual magna flow exhaust and k&n cai
Brodie douglas is offline   Reply With Quote
Old 02-29-2020, 09:46 AM   #2
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
Engine idling at normal operating temperature, the Fuel Pump Flow Control Module Fuel Pressure Sensor parameter should read between 300–400 kPa (43–58 psi). This is stock parameters.
fhrex is offline   Reply With Quote
Old 03-13-2020, 03:53 AM   #3
SonicChris
SonicChris's Avatar
Drives: 2011 RS
Depends on if you are before or after the high pressure fuel pump
SonicChris is offline   Reply With Quote
Old 03-13-2020, 10:07 AM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
If he's at 455# before the HPFP I think he has other problems to worry about lol
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
