01-16-2020, 09:00 AM | #1 |
Drives: 2013 Camaro Join Date: Feb 2016
Ported TB
I'm thinking of getting one for my Camaro. Which brand should I get? Will I get a check engine light if I have a tune on my car? It's 2013 v6.
Thank you. Sent from my moto g(7) using Tapatalk |
01-16-2020, 01:22 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
No CEL. VMAX is what comes to mind for stock size. There's also an 80mm TB available if you search for it.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
01-16-2020, 05:29 PM | #3 |
01-17-2020, 10:54 AM | #4 |
Throttle response is more a tune issue. Overkill tunes resolve it. Will you get better response though, probably.
01-17-2020, 12:22 PM | #5 |
I’ve got ‘14 lfx with 80mm tb, overkill tune since he’s the only one to take 80mm into account for tune. You can also get 80mm tb from will at overkill online or jacfab, I believe. I also have corsa exhaust, 80mm ported intake, k&n cai. I think I’ve done about as much as possible to retain reliability other than FI. I like how it responds and drives now. But some of the v6 issues come from trans and rearend gearing. I fixed the v6 issues by getting a Z28. Much better response now, although I’m keeping v6 for driver because it is very fun as well but I’ve replaced entire suspension.
01-19-2020, 02:22 PM | #6 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
I’ve got similar mods as GhostrdrZ and noticed a bit of a decrease in low end acceleration when I switched to the 80 mm TB by Overkill. Mid/upper power did increase though. Then I switched to 3.91 gears in the back. Now, with that 80 mm Tb and gears, it seems like the absolute perfect combo for a terrorizing but reliable V6 Camaro. I agree with another knowledgeable post, I believe it was by Apex Motorsports, that a rear end upgrade is the biggest bang for the buck upgrade you can do on the V6s.
01-20-2020, 10:43 PM | #7 | |
01-21-2020, 11:27 AM | #8 |
3.91 is a lot of gear for either the manual or the automatic V6. If you're an automatic you'll need to change the rear hubs, axles, differential and rear driveshaft (I think, not sure on that one) to the SS equipment to be able to use the gears.
If you're a manual you can use all the same gear options as the SS.
01-21-2020, 11:40 AM | #9 | |
01-21-2020, 12:05 PM | #10 | |
01-21-2020, 01:31 PM | #11 | |
All manual V6s have SS rear ends. It was a big deal when Richmond? came out with 3.55 gears for the 7.6" in the automatic V6s.
01-21-2020, 01:36 PM | #12 |
01-21-2020, 02:01 PM | #13 | |
Gotcha. I thought you meant LS going along with the L99 as in same rear end as the L99 and LS3. My mistake. Good point though. Automatic V6 isn't limited slip, manual V6 and all V8s are. Important.
01-21-2020, 09:12 PM | #14 |
I bought a used 3.91 diff, axles, and the back half of a SS driveshaft from a member here in AZ for a bit north of $1k. Then bought new hubs (got a steal at $112/pair) and seals to go with BMR poly diff mounts. The rear end is solid and eliminated the wiggle in the V6 diff with rubber bushings. I read a lot of members & vendors who said “that’s a lot of gear for an auto.” But for me, it’s perfect. I was slightly nervous that first would be too short upon first drive, but it’s not at all. I do think GM should’ve offered the 3.91s in a V6 so buyers who were potentially interested could see how they felt. No change in gas mileage, either, and I do launch it hard semi frequently.
