04-27-2017, 04:11 PM | #1 |
Drives: 2020 Camaro ZL1 Convertible Join Date: May 2014
Front and rear dashcams?
hey gang, new 17 vert ZL1 owner. Had a 14 vert ZL1.
I'm thinking about getting dashcam(s) installed. Are rear dashcams even an option for our verts? Has anyone mounted a rear facing camera on their 6th gen convertible?
-d00mz
2020 ZL1 Convertible in Shock -Bone stock (for now) 2017 ZL1 Convertible in Hyper Metallic Blue (sold) -stock 2014 ZL1 Convertible in Red Hot (sold) -Roto Fab Cold Air Intake with larger HX Rez -2.5inch upper pulley, solid isolator -Ported Blower Snout -ARH 2 inch headers and longflow off-road pipes -1000cc fuel injectors -NGK TR71X plugs -Catch Can -Dyno tuned to 600RWHP -All work done by Advanced Modern Performance |
04-27-2017, 04:23 PM | #2 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Wanting to know this as well.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
04-27-2017, 09:29 PM | #3 |
Drives: 2017 Camaro 2SS Fifty Edition Join Date: Jan 2017
I did a front install with the thinkware f770. I'm working on where to mount the rear cam. so far the only thing I can come up with is an interior type cam
04-30-2017, 04:17 PM | #4 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
You have some photos of the install? How does the night vision and time lapse work (why is hard wiring required)? How has it performed?
05-01-2017, 10:08 PM | #5 |
Drives: 2017 50th SS convertible Join Date: Oct 2016
I am running a Z-edge z3 on the front. 100 bucks on Amazon. I'll be getting another for the rear. I use go-pro mounts.
05-02-2017, 06:52 PM | #6 |
I really want something that is as hidden as possible from both inside and outside the car.
05-03-2017, 01:40 PM | #7 |
What would be the solution for mounting in the rear? Using a suction cup on the rear deck would be a problem with the wires getting tangled up in the top as it goes up and down. The brace just behind the rear seats might work next to the keyhole for opening the trunk if you could find a non-destructive way to attach. I don't want to drill holes.
Richard
05-04-2017, 08:14 PM | #8 | |
I converted my Z-Edge Z3 camera attachments to use Go-Pro devices that I got off Amazon. I also bought a 1/4 20 nut from Lowes to tighten things up on both ends of the screw. I plan to put a go-pro base on the plastic lip behind the passenger side headrest and then use the mount to extend it up and back like they use on helmet cameras. This part. https://www.amazon.com/ProGear-Tripo...+pro+converter Mounting it sideways may be easier just to get the base on and off from a parallel to the seat connection. I was going to tinker with both as I already have bot of the parts. https://www.amazon.com/GoPro-Side-Mo...M37ZHSNKWQJF30 The link below shows the converter part from Amazon. They call it a Arkon GoPro HERO Mount Connection to 1/4 inch 20 Camera Mount Adapter https://www.amazon.com/Arkon-GoPro-C.../dp/B00IQ7PRHU Last edited by Donner; 05-07-2017 at 03:49 PM. |
05-06-2017, 01:40 PM | #9 | |
Thanks for all of the feedback. I'll be looking forward to seeing what it looks like and how it works when you get it all together.
The first link didn't work. Quote:
Richard
05-07-2017, 03:49 PM | #10 |
