10-02-2020, 09:40 PM | #1 |
Drives: 2010 Chevy Camaro 2SS Join Date: Mar 2020
Power Steering Pump Pulley
Does anyone know where I can get a replacement power steering pump pulley for my 2010 Camaro SS ?! Is there possible a different pulley that may bolt up. GM apparently discontinued it and I cannot seem to find one locally.
2010 2SS w/ Magnaflow 2.5 muffler, CAI Intake, Stainless Power LT headers, e85 Custom Tune, vararam power wedge, Vararam Ported TB, BMR rear sway bar, BC Racing coilovers.
10-02-2020, 10:27 PM | #2 |
Wow. Why the hell does GM keep doing this? So many vital parts keep being discontinued. I really need a driver side door wiring harness. I bought a new one 2 years ago no issue, but now that I need another one...discontinued. I had a bad leak in my door from the sunroof drain and the harnesses kept getting damaged.
Anyhow, I found a kinda pricey ($100) billet aluminum pulley for you. It does seem to be stock sized though, which is good. Others I have found are undersized. The listing references the stock part number 12610794. Really nice looking part actually. Press fit. This might be your only option unfortunately unless you go to a salvage yard. If I had no choice I would go this route as it's not really obscenely overpriced for what you get. https://www.ebay.com/itm/2010-2012-C...oAAOSw2NVfY7Bw
10-02-2020, 10:40 PM | #3 | |
10-02-2020, 11:56 PM | #4 | |
Anyhow, I'm glad you ordered it. It looks like a very nice quality part and it will look great in the engine bay. Thanks for the challenge btw. I love searching for hard to find parts, weird I know.
10-03-2020, 02:14 AM | #5 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Salvage yard ??
10-03-2020, 10:39 AM | #6 |
Drives: 2015 Camaro Join Date: Aug 2018
I thought there was a law/rule that states they have to make parts available for up to 10 years after production?
10-03-2020, 10:56 AM | #7 | |
