06-20-2020, 11:16 AM | #1 |
Drives: C7 Z06 Join Date: Jun 2018
ZL1 vs 1LE Ground Clearance?
Sorry if this has been asked - I searched for a while before posting.
Is there a difference between ZL1 and ZLE ground clearance? I used to have a 2018 ZL1 that barely cleared a steep driveway and want to know if I should expect the same from a ZLE. |
06-20-2020, 12:40 PM | #2 |
Drives: 2015 Camaro Z/28 Join Date: May 2019
Very valid question for sure.
06-20-2020, 03:08 PM | #3 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Jun 2019
The clearance is the same. And the ZLE can actually be lowered in the nose
06-20-2020, 03:10 PM | #4 |
Drives: '19 ZL1 1LE Summit White M6, PDR Join Date: May 2019
The ZLE is probably a bit lower with the DSSV suspension and slightly different front splitter. My Mom's driveway isn't even that steep, but going over the curb entering her driveway raises one back tire off the ground because the chassis is so stiff. Just something to consider with the driveway you describe.
06-20-2020, 08:19 PM | #5 |
My Z/28 sits a tad higher than a ZL1 ... Fyi ... don't know why, but it does.
I hardly ever scrape anything. |
06-20-2020, 09:13 PM | #6 |
Drives: 2019 ZL1 1LE Join Date: Dec 2019
My 1LE scrapes on very slight transitions... it is an issue , so be very careful. The front splitter is the usual victim..,
06-20-2020, 09:20 PM | #7 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I did the square APEX ARC-8's 19x10's with 285/35-19's and I get a little more clearance now compared to the stock wheels and some areas where I visit seem not so bad now compared from before.
06-20-2020, 09:49 PM | #8 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
This and low cost of the Undertray I cracked on track seem to be kept low by Chevy to make common points of track damage affordable, which is a nice surprise. |
06-20-2020, 10:08 PM | #9 |
Buy the 14/15' Z/28 and be the highest of all Camaros!
I never scrape. |
