Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 08-05-2013, 01:48 PM   #1
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
thinking about 3.70 gear
Ok am running the 4L80E trans shift point at 6600 rpm was trapping 5200 rpm with 3.27 put in a M6 rear with the 3.45 now trapping at 5400 rpm in 3rd gear. I would think i need to trap at 6000 are a little more. Maybe go with 3.70 to off set the high gear of the 4L80E? What do you track pro's think?
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 08-05-2013, 02:25 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
What does it run and what power does it make. And what is your goal?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 08-05-2013, 03:20 PM   #3
Mr. Nasty
Mr. Nasty's Avatar
With good temps high 10s @127 but in this heat low 11s @ 122. 585 rwhp right now would like more down the road but will need lots of $$$$. For now want to make the best of the HP that i have.
Old 08-05-2013, 04:37 PM   #4
429
Drives: 2010 camaro ss
Put 4.10s in the car if you want to make the most out of your setup and cross around peak power. 3.91s would be a compromise gear. 4L80 1st gear is a turd, you need rear gear to get the car going.
From 3.45/5400rpm
3.70 - 5788 rpm
3.91 - 6118 rpm
4.10s - 6372 rpm
I cross ~135mph with 3.91s, and it isn't enough gear (car needs 4.10s)
429 is offline   Reply With Quote
Old 08-05-2013, 07:22 PM   #5
Mr. Nasty
Mr. Nasty's Avatar
With the rpm you have there dose that takes in count with 3rd coming in sooner? am past the 1/8 when 3rd hit as of now.
Old 08-05-2013, 07:39 PM   #6
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
From 3.45/5400rpm
3.70 - 5788 rpm
3.91 - 6118 rpm
4.10s - 6372 rpm
Go woith the most gearing that will have you at the top of your rpms crossing the traps. That's why I went with 4.57s.
SUX2BU is offline   Reply With Quote
Old 08-05-2013, 08:23 PM   #7
429
It doesnt matter. 1:1 gear is 1:1 gear.
Old 08-06-2013, 11:17 AM   #8
Pro Stock John
Writer
What size converter do you have mr nasty.
PROJECT HEAVY CHEVY
Old 08-06-2013, 03:07 PM   #9
Mr. Nasty
Mr. Nasty's Avatar
FTI 10.5 T/D 3000 stall
Old 08-07-2013, 02:52 PM   #10
Pro Stock John
Writer
So how does it 60 now?
PROJECT HEAVY CHEVY
Old 08-07-2013, 03:26 PM   #11
Mr. Nasty
Mr. Nasty's Avatar
when temps are 80 and lower 1.51 to 1.61. Was at the track this pass saturday temps was 95 60' 1.65 to 1.72 the heat kills the supercharger.
Old 08-07-2013, 03:28 PM   #12
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Nasty what's your combo? cam,boost and so on? any dyno #'s?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 08-07-2013, 03:49 PM   #13
Mr. Nasty
Mr. Nasty's Avatar
whipple with 12lb boost blower cam LT header forge bottom end stock head with studs. 585 rwhp 525 rwq. I feel like am leaving a better et time trapping at 5400 rpm with the 3.45 gears.
Old 08-07-2013, 03:54 PM   #14
Pro Stock John
Writer
Where do you want to trap, like 6500 for example? Where does the combo start to die off?
60 is pretty good for the tire/converter + 2.48 first gear in the trans. Just hooks and goes?
PROJECT HEAVY CHEVY
