Old 10-20-2021, 06:55 PM   #1
gosutag
Left Lane Enforcer
Drives: '18 ZL1 1LE.
2018 ZL1 1LE won't start without jump box
My Camaro won't start without a jump box. It'll only do 1, 2 or 3 clicks. Once I connect a jump box it starts easily. My battery is new. Anyone have common reasons? Thank you all to those who help.
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
2014 Chevy Malibu LTZ
gosutag is offline   Reply With Quote
Old 10-20-2021, 07:02 PM   #2
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Check the connection on the starter and your ground wire from the battery.
Old 10-20-2021, 07:41 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
check connections at the battery...the weird connections on the top posts may not be tight or contacting properly...
Old 10-20-2021, 08:52 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Check grounds too.
Old 10-21-2021, 08:31 AM   #5
Alain
Alain's Avatar
+++++1 on this.
I had issues starting my 2018 and it turned out to be a loose positive cable connection at the battery.
I take out the battery every year for winter storage. When I put it back this year I didn’t connect the positive terminal fully.
It’s a weird setup GM used to lock the positive terminal on to the battery post. Mine wasn’t fully seated so I would get random no starts and check engine lights for the parking brake.
Once I addressed the battery terminal, all issues went away.
Don’t count on the fact that you may not have removed battery. Someone at the dealership or at the assembly plant could have made the same mistake I made when installing the battery.
2018 ZL1 1LE/Red hot
Old 10-21-2021, 03:33 PM   #6
gosutag
Left Lane Enforcer
Check grounds too.
Is there a grounds diagram? I wanted to look at all of the grounds.
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
