10-03-2021, 09:12 AM | #1 |
Drives: 2021 LT1 Auto Join Date: Feb 2016
First trip to atco in my LT1
Best run was a 12.444 @115.74 it spun a bit and I have 10 speed auto I used the launch control. That was my first run it was about 62 out after that the temp dropped to 52 and I was fighting the 245’s and did not got any faster. But the good news is I picked up the 9.5 inch ss rims the other week that match my factory ones. Just have to find some rubber for them
Coming for my bolt on 5th auto as well I am very happy with my 6th gen. Bone stock very impressive and there is more there once I have some grip.
04 montecarlo SS totaled 130k
05 montecarlo SS supercharged sold 126k 2010 Camaro SS ( scarlet) |
10-03-2021, 03:24 PM | #2 |
Nice
Nt555r2
10-04-2021, 05:33 PM | #3 |
Yea I was thinking about getting the nitto 555r2 in a 295/35/20
10-07-2021, 10:40 PM | #4 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
That being said I wish they had a little more traction (I guess we all wish tires would have as much or unlimited traction, I guess unless you want to do burnouts). Trying to launch with them I think only a few times I have been able to get almost no spin during launch. I haven't been able to test them on a track, but when I go to launch and stall up to about 1700 I get just a little chirp. However them being drag radials they have obviously had way more traction than any other street tire I have had. I haven't been able to 100% conclusively conclude that a little spin/turnover/light burnout helps before launch but it seems it does. That being said its weird how random and inconsistent launching can be. It usually feels like when you think you see really good clean and flat pavement and you are feeling a really good sticky launch and the sun has heated the pavement, that's when you get the worst launches. And then it seems when you are least expecting any decent launch it just randomly hooks out of nowhere. I want to try the NT05 drag radials since I guess they are supposed a 0 treadwear instead of 100 treadwear like the NT555R2's. It would be so nice to be able to put all the power you are making to the ground instead of wasting it spinning, but thats what we get for having rear wheel drive. |
10-08-2021, 09:35 AM | #5 |
The tried and true to do that would be the ET street R on a 17. But then you’re not on stock wheels in the back
10-08-2021, 10:03 AM | #6 |
There is no tire that will dead hook with no heat in the tire....especially R compound tires. They need some heat to activate the compound per say. There is just no way around it. Even a Mickey Street R on a 17 isn't going to hook cold.
2016 NFG 1SS A8
10-08-2021, 12:38 PM | #7 |
I agree, I have 2 sets of 555R2s. One set for Drag Racing and one set for the street. They need heat in them for sure and you don't have to kill them trying to get them hot, short smoky burnout in the water box and good to go. Mine hooked good enough to break an axle on a Vette that makes under 480 rwhp. I run a taller 305-35-19 for the street and 285-40-18 for the track.
10-18-2021, 11:25 AM | #8 |
Drives: Wild Cherry 2021 Camaro LT1 RS Join Date: May 2021
I took my 21 LT1 to the track this weekend and was able to get a 12.1 @ 116 out of the car on the stock 245 run flats. I did a 1.85 60ft. Only thing I did to the car was let the air pressure down to 20psi.
10-21-2021, 06:47 PM | #9 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Thats a great 60 ft time. Did you leave off idle and just mash it? and you really dropped pressure to 20 psi in the rear...
10-21-2021, 06:52 PM | #10 |
10-22-2021, 07:24 AM | #11 |
It’s the 275 and dead hooks with heat in them. I might be changing to the 305 for height for the a10. I want to see how the shorter 275 works first. If I had to start I would go with the 305 for the a10.
The car was never dynod, tuned at the track.
10-22-2021, 07:59 AM | #12 |
That is great info , thanks. You would think if the 275 hooks that good with a manual, they should hook the A10 car as good or better. The 305 45 17 is 28 inches tall, how short is the 275 tire? and are they 275 45 17?
10-22-2021, 08:15 AM | #13 |
Thats right and 275 is 26 and change. My 16 car runs the short tire in the back but many others had the abs go nuts doing the same, therefore that mismatch in sizing isn’t recommended and run a 26 in the front. Thinking the 22 will not like it. Having the right height tire certainly has its perks.
10-22-2021, 08:30 AM | #14 | |
