Old 08-07-2021, 01:11 PM   #1
futurelabs27
Drives: 2016 Chevrolet Camaro 2ss
Something is off with my 16 Camaro 6 LT1
My engine seems to be working harder than usual. When vehicle is at a standstill, the RPM is sitting at 0.5. Shouldn’t it be sitting on 0? I noticed this issue after getting an oil change from jiffy lube. I’m not sure what was done but it was done poorly. (They didn’t even tighten the oil cap and it was sitting unscrewed for a few days)
Please help. I love my Camaro.
2016 Camaro 2SS
90,xxx miles
futurelabs27 is offline   Reply With Quote
Old 08-07-2021, 02:05 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
If the engine is running at idle then 500 RPM is the normal idle speed. The tachometer is electronic and controlled by the ECU so it seems unlikely that the JL staff could have done anything to affect it. I would check the dip stick to make sure that the engine oil level is correct. The LT1 in the Camaro requires 10 quarts of oil and not adding enough oil is the most common mistake made when changing oil.
