07-29-2021, 10:30 AM | #15 | |
ive had them on for 3 months or so 2 events driven there and back and 2 race days no problem so far a little noisy on streets but not bad
07-29-2021, 02:59 PM | #16 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
07-29-2021, 04:35 PM | #17 |
not sure but i heard they are tough on rotors on the track lol ill send you photos if you want first one was bad now its more even
07-29-2021, 05:04 PM | #18 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
I noticed that at the track the rotors get roughed up pretty good and the appear to smooth out somewhat after I put the stock pads back on and do some driving with them on the street. With the initial BITE with the DTC60/70 pads being much higher I can see how that attribute wouldnt be all that desirable in constant stop and go driving with air flow being limited to help cool off the braking system due to the much slower speeds..
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
07-30-2021, 10:58 AM | #19 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Hawk lists the operating temperature of DTC-60 and DTC-70 as 400-1600°F. I suspect running them on the street would be below the minimum temperature and could cause premature pad and/or rotor wear.
For comparison Hawk HP+ operating temperature range is 100-800°F. https://www.hawkperformance.com/compounds/motorsports I have heard this too about Hawk DTC pads plus that they are harder to modulate for trail braking compared to stock pads but I will probably have to get better pads to go with my second wheel set with 100 treadwear G3R tires at some point. I am planning to try them with stock pads and SRF brake fluid first to see if they fade...guessing they will at least to some extent but hopefully they don't overheat badly enough to boil the fluid. The G3Rs wore my rear StopTech Sport (309.14050 front, 309.17180 rear) brake pads extremely unevenly the first (and so far only) time I have run those tires...probably due to overheating...wasted half or more of the rear pad thickness and slightly boiled my 6 month old StopTech 600 brake fluid too after 2x 20 minute sessions. But those pads were quite a bit cheaper than stock pads and on stock SC3 tires they performed similarly to stock pads with similar wear rate just requiring a little more pedal pressure. The rears also wore several mm faster on top than bottom with stock SC3 tires but it was possible to flip them to extend their life. The rears have been backordered for 6 months though. These StopTech pads are not advertised for use with 100 treadwear tires so it is my fault for trying. Plus it was at the NOLA Indy Straight layout which is notorious for being hard on brakes. There is also good 1LE brake pad info here: https://www.camaro6.com/forums/showthread.php?t=475866 Last edited by cdrptrks; 07-30-2021 at 03:22 PM. |
08-01-2021, 12:44 PM | #20 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
If you look at the spider charts, the HP+ rating for low rotor wear is no better than what Hawk provides for the DTC family. My own personal experience with HP+ mirrors what Hawk's spider chart displays. Norm
'19 WRX 6M (the family sedan . . . seriously) |
09-13-2021, 08:09 AM | #21 |
Drives: 21 SS 1LE Join Date: Jul 2021
Anyone got part numbers for Hawk DTC 60 and 70 for front and rear on a SS 1LE?
09-13-2021, 09:00 AM | #22 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-13-2021, 09:09 AM | #23 | |
09-13-2021, 09:07 PM | #24 |
I love the DTC-60s with G3Rs on track. At $400 per set the price point is great.
Best price is at Tire Rack. Front Rotor rings get changed annually.
09-13-2021, 09:09 PM | #25 | |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
09-21-2021, 10:11 AM | #26 | |
I had the chance to run the DTC pads on the street for short periods of time. I had to drive my car to and from the track a couple of times with my race setup since I did NOT have access to a trailer at the time. With the street tires on, I found that the DTC Pads DID NOT immediately apply pressure to the rotors (it felt like there was a small delay). I would imagine that is because they need more heat to work properly. I DID NOT do alot of stop and go driving on the DTC pads on purpose but the bottom line is, the car felt MUCH better on the street with the stock ZL1 pads as the brakes were initially much more responsive to the brake pedal when I was using street tires vs. using the DTC pads.
09-21-2021, 12:38 PM | #27 |
Drives: 2019 SS 1LE Join Date: Jun 2020
Word to the wise anyone using Hawk DTC60s on track. I ran them in the wet twice at Road Atlanta. Stock rotors and wheels on my 1LE. The brake dust turned into cement on my wheels, nearly impossible to get off. I've used every kind of acid and cleaner. Only thing that works is paste wheel cleaner and chipping away at it slowly. I switched back to OEM pads as this is my daily. Just be careful if you run the DTC60s in the wet.....
10-12-2021, 10:51 AM | #28 |
i just tracked my car sunday and it rained hard monday night so after work i came home and washed my car in the rain haha
my wheels are ceramic coated and i use this stuff so it wasnt too hard to get off but i was super worried https://shinesupply.com/products/cool-guy
