Old 02-14-2021, 12:32 PM   #15
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Originally Posted by Kerry View Post
I put cladding under my vert and to me its much quite not near as much tire road noise. Its noticable for sure and fits with out much hassel. Have to cut a small notch where the midde of the brace bolts under the floor board but the rest is the same. A worth mod I would say for sure
Kerry, do you have the part #’s?
I may want to give it a shot too.
Old 02-14-2021, 08:56 PM   #16
Kerry
Drives: 2019 2SS Camaro
I dont, i took it off my coupe but Im gonna need to find out to put it on the coupe
Kerry is offline   Reply With Quote
Old 02-14-2021, 09:07 PM   #17
Chutzpah
Chutzpah's Avatar
Ah, ok... no problem. I’ll figure it out.
Old 02-19-2021, 02:48 PM   #18
Kerry
So I have part numbers of 23390130 and for the other side 23390131 about 60 bucks each. I think it really helps
Old 02-19-2021, 05:55 PM   #19
GroundhogSS
GroundhogSS's Avatar
What part of the car are those pieces put? I can't tell from the small drawing. GM parts direct has them for $57 left side and $59 right.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 02-19-2021, 06:13 PM   #20
Chutzpah
Chutzpah's Avatar
Thanks Kerry!
Old 02-19-2021, 10:27 PM   #21
Kerry
They are supposed to be the gray peices that go underneath the car right and left. Its like a gray carpet cardboard type stuff. it is exposed to the weather. U will need some nuts to bolt it on. The studs are there. Up front their are a couple clips that slide into the frame and then a 10 mil headed bolt goes into. This is starded on the ss coupe but for some reason no on the vert.
Old 03-21-2021, 05:58 PM   #22
bereic
bereic's Avatar
Drives: Camaro SS 2018 Convertible
This is what i was asking myself since a while if it is possible.
Do you have some pictures to see how it looks and where you had to cut?
Thank you
bereic is offline   Reply With Quote
Old 03-21-2021, 06:52 PM   #23
Kerry
like a inch sq on the edge where the bolt goes on the frame. no big deal at all. just do it and you will see. need the nuts and 2 bolts on the front with the clip. per side like the fender liners have
Old 05-13-2021, 08:45 AM   #24
bereic
bereic's Avatar
Do you know the torque of the bolts to be used on the x arms under the car?
Thank you
Old 05-13-2021, 10:00 AM   #25
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
43 ft-lbs for both the main X-brace and rear X-brace.
Old 05-14-2021, 02:03 PM   #26
bereic
bereic's Avatar
Thank you
Old 05-14-2021, 04:30 PM   #27
Kerry
I dont know if its relevant but you do not have to touch the bolts on the braces to put on the cading
Old 05-17-2021, 03:59 AM   #28
bereic
bereic's Avatar
Does someone have the part number of the nuts which goes on the studs?
