10-17-2021, 05:31 AM | #29 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Does anybody look at the dates of these threads anymore?
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
10-17-2021, 08:58 AM | #30 |
Obviously not!
10-17-2021, 11:01 PM | #31 | |
Drives: Camaro Super Sport, Six on the Stik Join Date: Jul 2021
The LT4 is setup from factory for Super Charging. 5.0 is physically bigger and heavier than the LT1. 5.0 Much more expensive to fix internals than the LT1 because it has much more moving parts with the double overhead cam setup. Last edited by Nilly Welson; 10-17-2021 at 11:15 PM. Reason: e |
10-17-2021, 11:20 PM | #32 | |
Are you sure your engine isnt running right? I have only had my SS 6 speed to about 120 on a track but it was pulling like a freight train until I backed off. |
10-18-2021, 03:43 AM | #33 | |
Drives: 2018 Camaro SS Join Date: Jan 2021
Agreed. You can buy a roush stage one and have an authorized service center put it on and it will not void your warranty. No internals needed. Also same for LT1. If you dont go over6-650ish WHP. Sent from my iPhone using Tapatalk |
10-18-2021, 06:55 AM | #34 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
His car is fine and he does make a valid point. After about 5200-5300 the motor runs out of breath. This is why you can watch countless videos of coyotes rolling right by the lt1 when racing from a roll.
10-18-2021, 10:03 AM | #35 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
One thing I will point out is you NEVER see any videos of NA manual gen 3’s racing camaro’s (or any other car for that matter). It’s always a10 coyote vs a10/m6 camaro. And I hate to say this but bolt on a10 gen 3’s seem to be able to keep up with cammed m6 LT1 camaro’s pretty easily as well. I am strictly talking about rolls. From a dig, the Camaro is definitely the faster car in the quarter regardless of stock, bolt ons, transmission type, etc. |
10-18-2021, 10:13 AM | #36 |
Drives: 2019 Camaro SS Join Date: Nov 2020
DOHC will always have more top end vs. a pushrod ( at least stock v. stock). Nothing an MSD and throttle body can't fix though.
10-18-2021, 10:25 AM | #37 |
10-18-2021, 11:09 AM | #38 |
It usually takes a high ram to keep up with a Gen 3 coyote bolt on for bolt on. It's more like heads, cam, fbo to take care of a fbo Gen 3 coyote comfortably.
10-18-2021, 11:25 AM | #39 |
Yep that’s what I am seeing as well. Gen 1 and 2’s are no problem. But gen 3’s with the a10 really can move up top. I’m still interested in seeing manual NA gen 3’s vs our cars but none of them seem to want to run. I bet they still suffer from clutch lockout and/or Ford neutered them in regards to gearing so they probably won’t post their videos if they lost.
10-18-2021, 11:43 AM | #40 |
Drives: like an old lady Join Date: Jun 2012
it's pretty simple
look at the dyno graph on a fbo e a10 coyote car. then figure out the shift extension. you should then quickly notice that the average power from gears 2-every gear is much higher than that of an LT1. i shift my bolt on m6 car at 6900 and it still falls back to 5100. there's a 30 whp difference at those rpms. edit: i have raced several m6 gen 3 cars and they are nowhere near as fast.
10-18-2021, 01:10 PM | #41 |
Going to assume you meant from a roll, but that’s what I was hoping to hear/see lol. As an M6 driver I could care less if an a10 beats me. But I was very interested in seeing/hearing how the m6 gen 3 coyotes (while remaining NA) ran against m6 lt1’s.
10-18-2021, 01:43 PM | #42 |
assuming traction, dig or roll, it takes a pretty damn strong m6 coyote car to come around a similarly modded LT1 car.
Thread Tools | |
