12-13-2018, 10:42 AM | #15 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
One way you can sort-of make a judgement on this is to go to Tire Rack and look at the rev/mile number (this number is specific tire related, where section width and diameter are sort of "standard" measures). Compare between the factory SS GY F1 245/40/20 rev/mile and whatever brand you are looking at. If the rev/mile is higher or about the same, you are good. If the rev/mile of the tire you are looking at is lower, be mindful the tire may not clear. Also, a more "stretched" a tire on a wheel, can gain you a little bit over a "pinched" (i.e. 275 on a 10" wheel vs. 275 on a 9.5" wheel). Last edited by Mountain; 12-13-2018 at 11:14 AM. Reason: mix-matched wording |
12-13-2018, 11:02 AM | #16 |
Conti ECS 275/35/20
vs. GY Eagle F1 AS3 245/40/20 and 275/35/20 FYI, I've seen people post that BFG Comp 2 A/S and Conti ECS in 285/35/20 are clearing for them, but every post I've seen with pictures indcates they aren't running much (if any at all) negative camber. FYI, those tires run 746/745 rev/mile respectively. Unfortunately, Tire Rack doesn't have the rev/mile specs posted for any Pirelli 285/35/20 for me to compare to. |
12-13-2018, 02:32 PM | #17 | |
Drives: ISO ss 1le Join Date: May 2018
12-26-2018, 11:52 AM | #18 |
Drives: 2018 SS 1LE Join Date: Jun 2018
Tires installed.
ended up going 285/35/20 305/35/20 Had to remover driver rear finder liner and reroute the harness. All back together now with ZERO rubbing. Looks great with no fender gap, thick sidewall tire, and fantastic ride control. The tire isn't overly sticky and is nice a quiet. |
12-26-2018, 12:30 PM | #19 |
Good to know we can run a 285/35 on the front w/o rubbing.
12-26-2018, 01:40 PM | #20 | |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
12-26-2018, 04:35 PM | #21 | |
12-26-2018, 07:10 PM | #22 |
Drives: 2018 Camaro 1LE Join Date: Dec 2018
I’ve ran 2 sets of the Indy 500s on my 2014 Mustang GT. They were Great tires. My only complaint would be the sidewalks were a little soft. Besides that they were great. Especially for the price! Good luck man!
01-03-2019, 09:32 AM | #23 | |
Drives: 2018 1LE Join Date: Nov 2017
Just want to say I have these on my 1LE with no issues. Front 285/35/20 Rear 305/35/20 |
01-03-2019, 01:04 PM | #24 |
01-04-2019, 07:35 AM | #25 |
02-14-2019, 02:52 PM | #26 |
02-14-2019, 11:59 PM | #27 | |
Might want to keep an eye on the driver rear liner - mine has some very minor wear just with the stock wheels/tires. |
02-16-2019, 09:48 AM | #28 |
Drives: 2017 1LE Join Date: Nov 2017
Mind sharing price? Good for shopping...
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
