12-02-2018, 01:31 AM | #15 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Thanks for the feedback, fellas. I’ll attempt to make some adjustments to settings and even try to get my tires warmed up a bit more before I attempt that next time. I haven’t used full traction control in a while so, I have no idea how that’ll be until I do it. I won’t be back in the states for another month and therein, it’ll be quite cold out so, I imagine traction will be fun regardless.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
12-02-2018, 09:03 AM | #16 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Has anyone been able to get close to zero camber on these cars? I'm not sure if it may require an aftermarket control arms?
12-07-2018, 03:04 PM | #17 |
Drives: '18 SS 1LE M6 Join Date: Feb 2018
I threw out some of the camber in the rear, and put on some sticky nitto DRs.
Yes this obviously sacrificed turn-in response & stability in tight corners. But I was willing to make that sacrifice seeing as how the car sees much more time going in a straight line than around turns. So it made sense to me. I plan on keeping the current camber level even if/when I go back to a street/stiff sidewall tire. The car now hooks despite whatever I throw at it. Not to mention I feel much safer knowing I won't throw my back-end into a pole if I push a tad too hard on the loud pedal.
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
12-07-2018, 03:26 PM | #18 |
Drives: '18 SS 1LE SW Join Date: Jul 2017
How much air is in your tires? I believe 32 psi all around is recommended, try going down a few psi in the rear.
12-07-2018, 03:34 PM | #19 | |
How close to zero were you able to get? |
12-07-2018, 03:50 PM | #20 |
I'll need to look for the sheet, but it was >-1.0
