04-11-2021, 03:16 PM | #1 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Brake piston compressor tool?
For those of you who change their own brake pads on an SS 1LE or ZL1, I need to hear your experience and advice on what to use to compress the pistons to make room for replacement pads, particularly on the front rotors.
It seems that most of the common compressor tools are designed for smaller calipers with 4 pistons at most. My friend uses a screwdriver against the (old) pad backing plate to force the piston back inside, but that's on a 4 piston set up and I worry about damage that may do the the pads an surrounding area. So what do you guys use to deal with the front caliper, 6 piston Brembos? Also, any experience with using the Girodisc brake caliper compression tool? The Porsche guys seem to like it, but it's definitely not cheap. |
04-11-2021, 04:06 PM | #2 | |
Drives: 2018 2SS 1LE in Nightfall Gray Join Date: Jul 2018
If you use this method, be sure to pump the brakes until the pedal firms up, you don't want to be going down the road and discover the pedal hits the floor! |
04-12-2021, 10:43 AM | #3 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
On this style of caliper I typically just take the old pad, rotate it 90deg, and use it as a lever to push the pistons back into the caliper.
04-12-2021, 12:23 PM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
I’ve always used a large C-clamp and the old pad to slowly squeeze the pistons back. I’m careful to keep everything lined up and square so the clamp doesn’t damage anything. I haven’t tried this on the 6-piston brakes but it seems like it should work. A thick cloth or slim wood block help keep the clamp from scratching the back of the caliper.
04-12-2021, 12:52 PM | #5 | |
yup same here c clamp with a towel if i need it works fine
04-12-2021, 01:13 PM | #6 | |
Hot Camaro
04-12-2021, 02:35 PM | #7 | |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
04-12-2021, 02:55 PM | #8 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I have freakishly strong fingers. Loosen the cap, then you can push the pistons in enough for new pads.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-12-2021, 03:45 PM | #9 |
Drives: 1LEs Join Date: May 2009
04-14-2021, 06:17 PM | #10 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I use the screwdriver method, putting the screwdriver between the worn out pad surface and the rotor.
I'll test my fingers on the next pad replacement.
