03-09-2021, 12:28 AM | #1 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Best brakes and Rotors Under $500 ?
What are your experiences and suggestions..want to upgrade my stopping power without breaking the bank here.. so what are the best brakes and rotors for both axles under $500 ? Links would be a great help.
Prefer slotted and drilled rotors. |
03-09-2021, 05:15 AM | #2 |
Drives: Camaro 1ss Join Date: Nov 2019
So you prefer your rotors to crack?
If it's not on this site it's most likely not any good. https://knsbrakes.com/c/car-items/49...+Front+Caliper
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
04-16-2021, 09:04 AM | #3 |
Chief Bief
Drives: Nightfall Gray Camaro 1SS Join Date: Dec 2015
The stock kit seems to work just fine. I would just replace the OEM equipment which would get you close.
2016 NFG 1SS M6 JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels. 426whp/434wtq |
04-17-2021, 10:40 PM | #4 |
An 500 bucks won’t go far won’t even cover one axle.
Orange Krush II
04-19-2021, 11:51 AM | #5 |
oem or bust or hit up ken at kns
04-19-2021, 01:40 PM | #6 |
retired badass
$500? good luck. I don’t even think eBay sells them that cheap. $500 might cover one axle. Maybe.
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts. Retired USMC |
04-20-2021, 07:23 AM | #7 |
Drives: 2019 2SS 1LE Join Date: Aug 2019
Upgrade your stopping power by upgrading your tires. OE brake pads & rotors are plenty capable of staying cool enough even under advanced driver pace on stock tires.
Brake hardware has no effect on peak braking force until they fade. |
Thread Tools | |
