Old 06-18-2019, 10:08 AM   #1
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
Daily Driver DOT 4 Fluid?
I tried searching and couldn't find the answer. I have a 17 SS that is mostly daily driven but I do take it up to the Carolina's/Tennessee Mountains. Last time I did this (deals gap) I cooked the brakes pretty good so just looking to slightly improve things to where I still have a DD that can handle the occasional spirited driving session. If the car ever sees the track it'll be a 1 off scenario so not looking to go full blown track duty but something that can hold the line between them both.
For the most part anything I see about DOT4 is you need to replace it every year or so which I would prefer not to do. Wasn't sure if that was just for that specific fluid or for all DOT 4.
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
Old 06-18-2019, 11:23 AM   #2
TJay74
You can run DOT4 but you will need to change it every 1-2 years, it absorbs moisture faster than DOT3.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 06-18-2019, 12:59 PM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
That's not necessarily the case. DOT 3 is actually a little more prone to absorbing water than DOT 4, it's just that the boiling point of DOT 3 doesn't degrade as much as DOT 4 does for the same amount of water content. DOT 4 is typically changed more frequently because people use it for track use where you want to be as close to the dry boiling point as possible so you typically don't go for more than a year or so without putting fresh fluid in.
As for what OP could do with mountain runs, if you're heating the brakes similarly to how they'd be heated on a track, you'll want to treat it like you're using it on the track. There's a video I saw floating around the forums where someone took their car to the track on DOT 3, boiled fluid, and slammed into a wall as a result. Annual DOT 4 fluid changes will help ensure you don't boil brakes or have issues, which is what I'd personally be doing if the alternative meant relying on a guard rail to keep the car from taking the quick route down the mountain.
If you want to be more scientific about it, temp strips/paint can be used to see what temps you're actually reaching. From there you can judge if there's a need for DOT 4 or not.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-19-2019, 05:07 PM   #4
Billabongi
Billabongi's Avatar
Thanks for the help was hoping there was a dot 4 fluid out there that could last two years (in my case about 14-16k miles in that time frame)
Will have to think about doing annual brake fluid changes.
Old 06-19-2019, 07:52 PM   #5
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I run Castrol SRF Dot 4 in my car and it's a daily that does not see the track, just mountain roads and back roads.
I plan to do a flush annually.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 06-21-2019, 10:07 AM   #6
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
I settled on Motul DOT 5.1 for my last 3 cars that see some light track duty (stock pads, tires, etc.) Not really sure what the water absorption rate is for that stuff, but it seems to be in a nice spot as far as boiling points somewhere between DOT 3 and the "racing" DOT 4 options. It's also cheaper than the mentioned DOT 4 fluids. Never had any issues on the street or track.
trohde78 is offline   Reply With Quote
Old 06-21-2019, 10:26 AM   #7
ZZP_Tyler
ZZP_Tyler's Avatar
Drives: 2017 Camaro 2.0T RS
I've run Pentosin Dot 4 in all of my cars the last few years, my daily as well as the car(s) that see the track. It has yet to let me down and can be found at Autozone for a solid price. Just make sure not to get the DOT 4 LV (low viscosity) version, they usually put them in the same slot on the shelf.
ZZP_Tyler is offline   Reply With Quote
Old 06-21-2019, 10:58 AM   #8
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Castrol SRF! i daily my SS 1LE and run 3-5 track events a year. I have about 20k miles on SRF fluid and I have only flushed once. Very happy!
Old 06-21-2019, 09:37 PM   #9
Billabongi
Billabongi's Avatar
Thanks all appreciate the assistance. Really curious about SRF but boy is it expensive!
Old 06-23-2019, 10:22 AM   #10
BlueinTN
Drives: gas powered
I run the Dot 4 type fluids for about 25 years now....I think they do draw in moisture more then your box stock DOT 3. Fluid color usually tells but you can get moisture test strips and test your self. I found a NOTICEABLE difference when changing the fluid so it was good enough for me.
usually yearly I just suck out the master cylinder with a turkey baster as far as I dare and replace with fresh fluid. On some of my rides with steering racks i do the same thing since they seem to over heat the fluid as well.
This isnt a COMPLETE flush but it gets the job done minimal mess,cost,stress.
Last few years the Motul 5.1 seems pretty good. My favorites fluids was the Castrol GTLMA but it went away a few years ago and I used up my old stock about 2 years ago.
BlueinTN is offline   Reply With Quote
Old 06-23-2019, 01:51 PM   #11
Billabongi
Billabongi's Avatar
Ive heard several people mention Motul 5.1 now and after looking at it that might be my first move. Seems to be great for street and light track duty. If I cook this one I’ll go up to 600 or SRF
Thanks for all the help everyone it helped me and I’m sure it’ll help others with the same predicament.
