09-15-2017, 07:18 PM | #1 |
Drives: 17' 1SS A8 Join Date: Jan 2017
Service stabilitrak ,Abs , and traction control light came and won't turn off
I topped of my brake fluid and that did not help. I also have pretty worn out tires which will be switched on Monday. So it started out when I would do a strong pull the lights would come on. Now a week later it's always on. I also have a small leak coming from my catless pipe . Anyone know what can be causing this ?
UPDATE***The code i'm getting is C0110 . Sent from my iPhone using Tapatalk
2017 1ss e85 /Rotofab/ Ported IM/TB Texas Speed 1 7/8th long tube headers with off road connection
09-15-2017, 07:21 PM | #2 |
Drives: 2017 50th SS convertible Join Date: Oct 2016
Did you try cycling the traction control switch?
09-15-2017, 07:22 PM | #3 |
Yes and it doesn't let me it stays the way it is Sent from my iPhone using Tapatalk
09-15-2017, 07:25 PM | #4 |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
Happened to me, but I had put on bigger profile tires.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
09-15-2017, 08:24 PM | #5 |
Drives: 2017 2lt rs Join Date: May 2017
Your bald tires and hard pull are doing this .wheels are sliding around like ur on ice.clear codes after you replace tires.
09-15-2017, 08:35 PM | #6 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Who did your tune? Who installed your headers?
I would check to make sure the harness on the passenger side of the engine compartment under the coolant reservoir is not on the header getting fried. |
09-16-2017, 05:25 AM | #7 | |
SABIO
Harness was touching header and melted the cover off one wire. Taped up and warnings are gone
09-16-2017, 06:13 AM | #8 |
Also check fuses
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME |
09-16-2017, 12:50 PM | #9 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Doubt this is the reason.
09-16-2017, 06:49 PM | #10 |
09-16-2017, 08:08 PM | #11 |
Did you actually read what I was doubting? I don't doubt other reasons, but bad tires isn't one of them.
09-16-2017, 08:54 PM | #12 |
Thanks guys I'll check the harness for damage
09-17-2017, 01:56 AM | #13 |
Drives: X-15 Velocipede Join Date: Mar 2008
Steering angle sensor defect causes these symtoms
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
10-24-2017, 04:13 AM | #14 |
ok guys so i finally scanned my car and The code i'm getting is C0110 .
1. pump motor circuit actuator stuck 2. pump circuit malfunction 3. Pump Motor Circuit open I really don't wana take it to the dealer with my mods. anyone know what may have caused this ?
