08-19-2020, 08:53 AM | #15 |
Drives: 2017 2SS convertible M6, NPP, MRC Join Date: May 2013
Agreed - And even during the day in a non-remote area, without a spare it's likely you're looking at getting towed, with all the cost and hassles involved. Driving home or to a tire store seems worth it.
Did you hear about the restaurant on the moon?
Great food ------ No atmosphere. |
08-19-2020, 11:09 AM | #16 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I carry a plug kit and an air pump. Should do for most leaks short of a major blow out.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
08-19-2020, 12:42 PM | #17 |
Hot Camaro
Add a jack and lug wrench and in the more populated areas, work out a deal with a rideshare driver to tote your blown tire/wheel to the tire shop and then get a ride back (they will take your luggage if you're going to the airport - keep a bag to put the wheel into so it doesn't get their car dirty and they will likely have zero issue with it - just be sure to order a larger vehicle). Certainly less than the cost of a tow and more manageable than having to try and carry a spare and possibly do damage to the top when it's down.
08-19-2020, 01:22 PM | #18 | |
Since I plan to take LONG trips when I semi retire, a spare that can run at 81 MPH for extended distances is key (for me). Last edited by Chutzpah; 08-19-2020 at 02:15 PM. |
08-21-2020, 08:56 PM | #19 |
Drives: 2020 SS Join Date: Aug 2020
I'll take pictures tomorrow. I put the spare in the trunk and there's plenty of room to spare. (no pun).
I took out the trunk floor liner, put in the Modern Spare tire, then put the liner on top of the spare. With the top down I've got manbe a 2 inches clearance above the spare and all kinds of room on the sides. I'll use a magnet to tool the safety partition and leave it down all the time. It looks like I'll end up with more useable space, if that is possible. The ass end of the car didn't seem to drop any from the weight and I'm sure I'll never notice the extra 40 lbs. I was on the fence but now glad I went ahead. I'll anchor it in and forget about it. I got the full kit with jack and tools.
2020 2SS
08-21-2020, 09:21 PM | #20 |
This thread is making a strong case for sticking with run-flats.
08-21-2020, 09:49 PM | #21 |
I've had all kinds of run flats on all types of cars. Any sidewall damage and you're walking. To each his own. A flat with a run flat, in town is great, anywhere else I'd rather throw on a spare and try to plug the tire when I get back to civilization.
I will run a wide summer only run flat in the warmer months and then switch to the reg tires in the winter. The softer sidewalls on the reg tires is pretty noticeable. Handling and stopping are a bit diminished but it rides great on the highway and the pot holes around town don't seem as bad. Like I said, to each his own.
2020 2SS
08-21-2020, 10:34 PM | #22 | |
08-22-2020, 01:39 PM | #23 | |
The verts trunk storage leaves much to be desired, so carrying a tire for a road trip isn’t really impacting how I’d travel. A couple duffel bags strapped in the back seat will work nicely. You do make an interesting point about jacking with a flat. The jack provided by modern spare is a toss up as to whether it will fit or not (with a flat, on ZL1). However, the structure is so rigid I know you can jack from a different pinch weld and in effect, lift the entire side of the car some. I’ll add a block of wood or structural foam to my kit... jack a bit, install block, lower jack, move jack to appropriate location for wheel removal. A spare may not be for everybody, I just know that waiting for help is not my style. |
08-22-2020, 01:51 PM | #24 |
08-22-2020, 02:09 PM | #25 |
Here are pics of the spare in the trunk with the top down. Note there are already cutouts for tools or tow hook.
We come from long distance motorcycle touring. Even with the top down and lugging a spare tire, we still have more room than we've had in years. In the blurry shot I was trying to show how much clearance you've got. One shot shows spaced gained on each side and now there's a pretty decent size place for the groceries. The silver box looks important so I'll protect that and anchor the tire down. We travel in a lot of remote places, I like to be able to at least try and get myself out of trouble. The last shot is a set of w/t for sale up the road. I don't need them but I want them...
2020 2SS
08-22-2020, 02:12 PM | #26 | |
08-22-2020, 02:27 PM | #27 | |
Where’s your tow hook? Looks to be missing. The silver box is an over complicated amp for your stereo, chimes etc. Looking into your trunk, on the right side, is one of a few fuse blocks. You’re right, you want want to protect the amp ....and the fuse block w/ connector..... |
08-22-2020, 02:39 PM | #28 |
Cool, thanks for the info!
2020 2SS
