Old 12-11-2018, 12:01 PM   #1
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
RPO Codes for our model.
Where can I find these codes listed? I’ve looked in the trunk and the glove box. Where else could this be listed?
I’m looking for the tpms rpo code to see if I need a 315mhz or 433mhz frequency for my second set of wheels.
I know this isn’t the wheels forum but it seems like each model has different codes and locations for things. Thanks for the help.
eaglesfan2006 is offline   Reply With Quote
Old 12-11-2018, 12:12 PM   #2
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Build Sheet
Contact: socialmedia@gm.com
Request a “Build Sheet” with your Vin:#
That will give you all the RPO codes for your vehicle.
Sweptwing is offline   Reply With Quote
Old 12-11-2018, 12:54 PM   #3
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Look on the underside of the truck floor piece that you lift to access the fuses and whatever else you want to see under there.
