12-17-2020, 09:49 AM | #15 |
Drives: 17 SS a8 Join Date: Feb 2010
I have mentioned it before. I think any complex fuel system should have a safety set up. Mine cuts power to the coils if the a/f ratio gets too high under boost.
This may not have caught your issue if it was a distribution issue but would have saved the motor if it was a meth or fuel supply issue. Anytime I am helping someone tune an aftermarket ecm I turn on all the safeties I can find. Fuel supply issues happen all the time due to a wide number of causes. Then add a whole 2nd fuel system and that likelihood goes up.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
12-17-2020, 09:51 AM | #16 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I’m sorry but I’m laughing so hard picturing the wife running away screaming.
12-17-2020, 09:53 AM | #17 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I agree it's a distribution issue, but why is it nearly always cylinder #7? Isn't #8 is slightly farther from the throttle body?
Baby Blue
12-17-2020, 10:06 AM | #18 |
Drives: 2016 Camaro SS Join Date: Sep 2018
12-17-2020, 10:32 AM | #19 |
It's always been that way since LS engines and my guess it has to do with the Intake manifold designs. There must be some sort of turbulence in the plenum that causes that cylinder to get more air and it seems to run hotter as well...so more air and less cooling.
2016 NFG 1SS A8
12-17-2020, 10:50 AM | #20 | |
You are not the first and won't be the last until people figure out relying on a Fertilizer pump to supply fuel to your engine through a single injection point can't possibly distribute fuel equally to all cylinders. And Direct injected engines are not designed to carry fuel vapor in the intake and combustion system. XDI fuel system and injectors with Fore Innovations low side fuel system feeding it, is the only way we will build a Direct injected engine at these power levels. I hear all the time Man that fuel system is expensive, Deduct your blown and engine cost, and meth system cost and you come out ahead. End Rant. Ted.
www.jannettyracing.com
12-17-2020, 01:55 PM | #21 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
And to note an MSD manifold. What I'm wanting when I do P.I.
12-18-2020, 01:24 PM | #22 |
Drives: 2018 Camaro SS Join Date: Sep 2009
I just don’t see it being a methanol distribution issue. There are a million and five people running methanol and most are not direct. A MSD is not restrictive or a particularly long runner intake. If your meth tank was full and your fuel pumps had a sufficient level to keep them primed, my guess is your fuel system was on the ragged edge of being capable enough to support your setup. The lack of miles and the cooler air requiring more fuel leads me to believe you may have not ever had an adequate supply for this setup. Prochargers have a sharp power curve that has a very slim peak. They don’t draw as much fuel early on or even through the mid range. It could very well be that insufficient fueling wasn’t discovered on your tuning day. It’s all speculation though. Really everyone of us could be wrong and I’m fully onboard with the others notations about using bigger injectors or secondary supplemental injectors as a safer alternative for a powerful build like this.
12-18-2020, 01:35 PM | #23 |
Drives: None at the moment Join Date: May 2018
This is why I want a ZL1 and not an SS then add boost.
12-18-2020, 05:28 PM | #24 |
Not a bad idea, however you can boost an SS to ZL1 power levels and maintain stone axe reliability. The OP was pushing well beyond these levels.
Baby Blue
12-18-2020, 06:45 PM | #25 |
Not to mention that the exact same problems will come up with the LT4 except at higher power levels... after all, who in here leaves their ZL1 stock?
12-18-2020, 07:43 PM | #26 |
Add an F1A-94 to a ZL1 with the same fueling and watch what happens...
12-18-2020, 11:03 PM | #27 |
Geeezzzz, let me guess. Its behind door #7.
12-19-2020, 01:04 AM | #28 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
My vote is it leaned out too.
IMO, the manifold is designed to be dry flow. Try to make it a wet flow and you will get fuel separation/fall out/distribution issues. "Just because you can doesn't mean you should"....
